Testing the Sound Blaster X7 vs Mother board built in audio
Just a loopback cable from audio output to audio input. To accurately measure distortion use the stepped sine measurement on the RTA window, it takes a long time if you use many points per octave but has very low noise floor.
Mat1926
Loopback cable is basically 3.5 mm male -> 3.5 mm male...correct?
Mat1926
Thnx a lot, I appreciate it...I will obtain the cable in the morning and do some tests...I will be back with my results/questions...
Thnx
