jmbgator
- Aug 3, 2021
- 5
Hi Everyone-
New user here and I hope you can help. I've spent countless hours trying to get my UMIK-1 and REW to work on my laptop with no success. A little info about my setup:
-Laptop: HP Spectre x360 running Windows 10 Pro
-Output: HDMI output from USB hub that's included with the laptop to a Denon X4500H AVR; connected via front HDMI slot
-Input: UMIK-1 mic connected directly to USB port on laptop
-REW Version: REW v5.20 vRC13b
-ASIO Version: ASIO4All v2.15 Beta 2 (I later installed FlexASIO v1.7a to see if that worked instead)
I followed the instructions posted in this forum setting it up in Windows. Windows seemed to have no issues identifying my UMIK-1 and my Denon AVR as soon as I plugged them in. I properly went into the the sound settings in Windows and made the proper configurations found in this guide, as well as ensuring that my mic is "allow access to my microphone" is enabled in my Windows privacy settings. I have also restarted my PC countless times; as well as closing all other applications (chrome, outlook, etc) before I open REW.
The biggest issue that I seem to be having is that I can't get REW to work nicely with my UMIK-1. In-fact, every time I try an SPL Meter within REW I get the error message below after a few seconds. It doesn't matter whether I have Java selected in my REW preferences menu, or ASIO; I still get the same error message.
Below are my preference settings when I either select Java, ASIO, and FlexASIO. Is there anything I'm missing or doing wrong? I can't seem for the life of me to get it to work...
JAVA
ASIO4All
You can see below that I've been having trouble getting my ASIO4All devices to "Active". They just sit in "idle" status even after restarting my PC and ensuring there are no other open applications. The output HDMI is the "HD Audio Driver for Display Audio", and the input UMIK-1 is the "Intel Smart Sound Technology for USB Audio".
FLEXASIO
With FlexASIO below, you can see that I can in-fact select the Denon AVR and UMIK-1. But I still get the same failure to connect issues when trying to run the SPL meter.
Unfortunately, I am completely lost in what to do next. I'm not sure if this is maybe due to a faulty UMIK-1 or due to something in my settings menu. Any help would be appreciated.
One test I did try to do was to use the stock Windows Voice recorder to see if the UMIK-1 recorded my voice. Unfortunately, the UMIK-1 did not seem to record any audio through that app. However, I was able to record a voice memo using the UMIK-1 connected to my Apple iPhone using a lightning to USB camera adapter. So the UMIK is able to record audio, I have just been having zero success with it working nicely with my PC.
Any help is appreciated guys. Apologies for the long post but I felt it is necessary to provide you the most amount of info.
JAVA
ASIO4All
FLEXASIO
