shauk_khan
- Aug 14, 2019
- 3
Hallo
We have recently brought the UMIK-X microphone array from miniDSP including the REW Pro version license. I have a question regarding performing a measurement.
The miniDSP user manual describes a multichannel measurement using REW, but that uses ASIO drivers and playing the signal from REW itself or from the measurement PC to the loudspeaker. Then it gives the option to have an rms average of the magnitude of all the channels captured. We want to have the same feature but our measurement setup and requirements is different as below
We want to perform the same measurement as above inside a car, but the measurement signal will be played externally (Pink Noise) from the car sound system. So my question is how can we do the setup to perform the measurement using the external signal and get the same results as above.
