Using REW for Testing Speakers to enable Crossover Design (using Xsim).
Nordo
Denon AVR X1500H
Sub amp - Behringer EP2500
Panasoic BD35
DIY
DIY
DIY
DIY
HTPC (windows 10 with Kodi)
Epson EMP-TW2000 projector
I've been using REW for years to refine my home theatre - room treatment, speaker placement, sub placement, etc.
However I am currently designing some TL speakers (woofer and a mid/full range driver).
Once I complete the cabinets and install the drivers, I need to test the seperate installed speakers for SPL (frd file) and Impedance (zma file).
Is there a tutorial/instruction somewhere that explains this process?
I believe with the impedance part I need a simple cable rig incorporating a resistor.
As I have done in the past, I will be using my laptop.
The only thing I had to connect to the laptop in the past was my miniDSP UMIK-1 microphone into a USB port.
But this time I need to connect to both the audio input and the output.
Is there a USB cable that can pick both the audio input and output?
The laptop does have a Headphone port (as well as the USB 3.0 port and a HDMI port), so maybe I have to use that for the audio out?
Any help would be greatly appreciated.
