Advice on speaker selection ?
Coy Ramsey
Yamaha Aventage RX-A660 AVR
4 Yamaha WX50 amps for MusicCast distributed audio
Sony X700
Elac Debut 2.0 BS5.2
SVS Ultra center to replace Elac Debut 2.0 CC5.2
Polk in-wall
Polk in-ceiling
RSL Speedwoofer 10s
Episode ceiling speakers for 4 distributed zones
Samsung
65"
Logitech Harmony
Spotify Prem, Netflix, Amazon Prime Video
Episode in-ceiling for distributed audio into 4 zones
14x14x9 room & MLP 10' from cc, old ears, damaged hearing (tinnitis), 5.2.2 system, Yamaha RX-A660 (Aventage, 80 wpc), 75% TV/movies, 25% soft
rock, clear dialog is top priority. Don't listen loud (-30 on AVR). Currently using Elac Debut B5.2 and C5.2 for L/R & cc, consider them good on music
and ok on dialog but would like an upgrade. Since dialog is primary focus, looking at center channel and matching L/R. Budget around $2k.
Consider 3-way Ascend Horizon w/Raal one of best cc speakers available but height is too high for my application (8" max).
Evaluating (, cc): 1) Ascend Luna + Duo, 2) SVS Ultra, 3) Elac Uni-Fi, and 4) Klipsch RP (500 series). Each option brings a different
technology solution to my problem. Willing to upgrade avr (i.e. Elac Uni-Fi) but would rather do this later as the next step of improvement after speakers.
Any inputs or experience with these options is appreciated.
Hi Coy, Not knowing where your hearing loss is, or your budget, I would suggest you take a look/listen to center speakers that have some ribbon or electrostatic technology if you are looking for something that is on the clear and crisp side of things... Also horns like the Klipsch you are evaluating and JBL... My preference is for Martin Logan and I am sure you can find others...
The important frequencies in Western languages are from 120Hz to 8kHz with the frequency band around 2 kHz is the most important frequency range regarding perceived intelligibility. You might look out for a center speaker that excels around the 2kHz range...
Coy Ramsey
Sony X700
Polk in-wall
Polk in-ceiling
RSL Speedwoofer 10s
Samsung
65"
Logitech Harmony
ddude - on frequency scans and with tennitis going on I'm pretty much shot after 10k-12k which is about par for my age, 75. Unfortunately, some manufacturers cross over their drivers in the 1500-2000 Hz range which seems very foolish. I have done some auditing of horns, ribbons, and dome tweeters but haven't tried the electrostatics. Typically listening rooms are set up more for music than for vocal auditioning, I need to develop my own vocal demo source.
philip vasseur
AVM60; STR preamp
MCA525
Mac MC312 MCA 225
Oppo 103
Revel 228be
Revel
Def Tech
SVS SB16 (2); GE XXL (2); SVS SB2000
Sonos Port
Parasound Halo P6 2.1
I'm 68 and have gone through a lot of speakers. Eventually I found Revel; they have speakers at all reasonable price points and their performance is based on science, not the flowery hogwash you read in reviews. They check their speakers using blinded comparisons against the competition before selling them. Check out their facility where they do the testing, no sure of a link offhand but you can search for it, and see the very recent review of one of their bookshelf models on audiosciencereview.com
Coy Ramsey
Sony X700
Polk in-wall
Polk in-ceiling
RSL Speedwoofer 10s
Samsung
65"
Logitech Harmony
Your choice should be a full range electrostatic loudspeaker, no better option for clear dialog.
The new Magnepan LRS is on my radar. Have never heard an electrostatic but reviews are good. Most reviews talk about them for music 2.1 use and very little about HT. How are the center channels ? For sure, I'd need to upgrade my electronics immediately however.
Coy Ramsey
Sony X700
Polk in-wall
Polk in-ceiling
RSL Speedwoofer 10s
Samsung
65"
Logitech Harmony
I'll check them out. I understand that ASR is very analytical and will dig thru their data.
Nordo
Denon AVR X1500H
Sub amp - Behringer EP2500
Panasoic BD35
DIY
DIY
DIY
DIY
HTPC (windows 10 with Kodi)
Epson EMP-TW2000 projector
@Coy Ramsey Hi Coy.
I'm 74. Don't have too much tinnitis, but definitely have lost the upper frequency reception.
I am not going to recommend any speakers, but make a simple suggestion.
After doing a recent equ'ing of my 7.1 system, I sat back for a listen.
However, based on something I read somewhere, I also threw a quilt over the back of my leather chairs.
Suddenly I could hear speech better than ever. And I also had to turn the whole system down.
A simple tweak I would definitely recommend.:T
Travis Ballstadt
Administrator
Seattle, WA
Anthem AVM60
Emotiva BasX 5
Emotiva UPA-500
SVS SB2000 x2
They still have those?
Before spending any money, I’d recommend swapping your center channel with one of your surrounds and live with that for a couple weeks. See if the improves anything.
You may be struggling because of lobing. Here’s a bit of an explanation:
Kal Rubinson
Active Member
NYC
Good point. The OP should only consider 3-way center speakers with vertically stacked mid and tweeter.
Grayson Dere
Bay Area, CA
Integra DTR 7.8
Class D Audio: SDS-470CS
Sony UBP-X700
Vandersteen Model 2
SVS PB-2000
Grado SR 325is headphones
JVC DLA-X75
Elite Screen 120"
Head_Unit
Denon AVR-X3600H
Oppo UDP-203
Focal 936
Focal CC900
Focal SR900
SVS SB-2000 Pro
LG OLED
Yup and yup! Though coaxial mid/tweet a la KEF or ELAC avoid lobing as well.
@Coy Ramsey I'd also riff on @Nordo's suggestion...I'd like to see PICTURES of your setup and room. Placement and aim can also kill centers, and reflections near the listening area kill intelligibility. Oh also consider using Yamaha's YPAO to EQ the mid etc if your hearing needs it.
Coy Ramsey
Sony X700
Polk in-wall
Polk in-ceiling
RSL Speedwoofer 10s
Samsung
65"
Logitech Harmony
This shot is a bit dated but shows the basic L/C/R setup. I have upgraded the small sub to a RSL Speedwoofer 10s. Yamaha Ypao plus cc is up about 6 dB. Many EQ mods tried.
40634
Grayson Dere
Bay Area, CA
Integra DTR 7.8
Sony UBP-X700
Vandersteen Model 2
SVS PB-2000
JVC DLA-X75
Elite Screen 120"
I'm VERY happy with the performance of my RSL Speedwoofer 10s! Good choice : D
Nordo
Denon AVR X1500H
Panasoic BD35
DIY
DIY
DIY
DIY
The room has many things I can see that could create a problem.
First, move the centre further toward the front of the cabinet, so that it hangs over the edge slightly.
Second, you can't have the coffee table where it is. It will be giving a reflection almost as strong as the direct sound. Replace it with a large thick rug.
The other problems will need a lot more work and thought.
The mains will be generating reflections - from the sides as well as the rear. The glass close to the left main will be particularly strong and bright.
If you want a good listening room, these will need to be tamed. Depending on the rest of the family, this may be difficult to achieve.
I would concentrate on getting the best sound, stage, etc. from your mains using quality records. e.g. stereo recordings.
Then do a similar thing with your sub. This time using recordings you know have a great bass.
There is heaps of information to help you achieve this, both on AV NIRVANA and other sites.
You just have to learn to separate the wheat from the chaff.
Nordo
Denon AVR X1500H
Panasoic BD35
DIY
DIY
DIY
DIY
BTW, something I found that improved dialogue in my home theatre.
We have soft leather seats, but on someone's advice I threw an old feather doona over the front seats (he actually suggested a soft blanket).
I found dialogue appeared to be much clearer.
I suffer from tinnitus only every now and again, but I have definitely lost a lot of my hearing's upper register (I'm 75 year old :olddude:).
Currently we are looking at selling our house (with the HT) and downsizing.
So my recent research into centres with clearer dialogue has concentrated on soundbars.
And there are definitely soundbars that concentrate on clarifying dialogue.
So I would assume there are websites that have tested and rated centres, including rating their clarity for dialogue.
AVA Cinema
I've struggled with dialogue for years... best speaker to overcome that was the MartinLogan Stage II that I once had... now I have the ML Focus C-18, which is even better. I've long had blankets (upholstered to fit) on the tops of my leather recliners. I have two fluffy blankets underneath my main listening position cover blanket to help absorb the sound off the back of it. Works very well.
Coy Ramsey
Sony X700
Polk in-wall
Polk in-ceiling
RSL Speedwoofer 10s
Samsung
65"
Logitech Harmony
That is very interesting. I'll need to research ML which had not been on my radar for an upgrade for my fronts. More than I intended spending but maybe the ESL model might slip past the auditor (WAF).
Nordo
Denon AVR X1500H
Panasoic BD35
DIY
DIY
DIY
DIY
The C-18 is top-of-the-line.
But ML do have other options.
Maybe if the C-18 is out of your range, Sonnie might be able to suggest something a little more affordable with a high WAF.
AVA Cinema
There is the Illusion ESL C34A that I wish I had room for, but I don't.
I have not heard any of their newer models that are priced less... but I was never impressed with some of the other centers that I had in the past. The Stage, Stage II and this C-18 are the only ones I felt were better for dialogue. I can't tell you they would be any better for you in your room and your setup, but they work better for me. However, I still bump up 750-2000Hz about 3-4dB when setting my target curve for the center.
Anyone heard a JBL compression horn as, or in, a center channel speaker??? I just wonder... :heehee:
I think @NBPK402 has a K402 MEH (Klipsch horn) for a center channel... :bigsmile:
AVA Cinema
I never have, but that might very well be a viable option... logically thinking.
Coy Ramsey
Sony X700
Polk in-wall
Polk in-ceiling
RSL Speedwoofer 10s
Samsung
65"
Logitech Harmony
Yeah, I keep drifting back to look at the JBL's as well. Sonnie's inputs are spot-on for the ML, thanks
I would extend @Sonnie 's bump out to 4kHz as the important frequency range for speech intelligibility is in the 1kHz to 4kHz range and centers around 2kHz...
