AV Showcase... Please Read Instructions!
The AV Showcase is now open for creating new showcases. These are either finished home theater rooms / audio listening rooms, or rooms under construction. Please choose the correct category. You can have more than one showcase if you have more than one room... and you can have showcases in the Finished Rooms category and the Under Construction category.
Please DO NOT create a new thread here for your home theater pictures... instead, use the showcase. It is easier to navigate the images with the showcase.
It is also VERY IMPORTANT that you DO NOT insert the images within the post after you upload them to your showcase. If you copy and paste them into the message pane, the system will upload them, so you have to delete the image out of the message pane area, but they will remain as uploaded attachments and will still show up in the showcase.
After you create and post your showcase, it will create a discussion thread here in the AV Showcase forum, which will also link to your showcase.
If you have suggestions or recommendations or issues pertaining to the AV Showcase, please post them in this thread below and we can discuss it.
