HDMI TEST BENCH: Vanco's Evolution 4K HDMI Wireless Extender with HDMI Loop-Out Review!
Manufacturer & Model
Evolution 4K HDMI Wireless Extender with HDMI Loop-Out EV4KWHDMI
MSRP
$995
Link
https://fave.co/4amynbM
Highlights
Compact size, capable of transmitting 4K@60Hz video with low latency over large distances, IR support, Loop-Out on the transmitter to share HDMI connection with local display or receiver, stable connection, smooth video, it works.
Summary
Vanco's Evolution 4K HDMI Wireless Extender with HDMI Loop-Out (EV4KWHDMI) is a wireless HDMI product that delivers on its promises. Designed to transmit long distances and through obstructions, the Extender kit can transmit a 4K@60Hz with two channels of audio. Operation is simple, construction is robust, and buyers will find cable-like performance. Drawbacks include a lack of HDR and multi-channel support, yet this kit does so much right, it's easy to recommend.
On this edition of HDMI TEST BENCH, we take a 4K HDMI Wireless kit from Vanco for a full technical test drive. The all-new Evolution 4K HDMI Wireless Extender with HDMI Loop-Out has a ton to offer and is the first wireless extender we've tested that can replace an HDMI cable between a source and a TV or Projector.
The kit offers wireless transmission of video signals up to 4K 60 Hz resolution with two channels of audio over 164-feet line of sight. It's also marketed as capable of passing through walls and floors, claiming it offers the same coverage as Wi-Fi. In addition to wireless HDMI, it carries directional IR so a source can be controlled remotely at a display's location, it also features an HDMI loop-out, where an additional local display can be connected.
We used various tools to evaluate the Evolution 4K Wireless HDMI Extender, including Murideo's 8K Fox and Hound Test Kit and real-world tests and evaluations. What did we find? Well, we found a heap of good with a few caveats. If you're looking for a high-performance wireless HDMI kit, this is definitely a review worth watching.
If you'd like to buy the Evolution 4K Wireless HDMI Extender with HDMI Loop-Out, you can do so through B&H Photo (click here to buy at B&H) or one of Vanco's distributors.
Vanco Evolution 4K Wireless HDMI Extender with HDMI Loop-Out EV4KWHDMI Specifications
  • Supports up to 4K@60Hz resolution
  • Wireless transmission up to 164ft/50m (line of sight) of low-latency UHD signals
  • HDMI loop-out to connect an additional local display
  • HDCP 2.2/1.4 compliant
  • Supports LPCM 2.0ch 32KHz/44.1KHz/48KHz Audio Formats
  • SSID pairing and channel switching to avoid interference
  • IR pass-through to control the source at the display location wirelessly
  • Size, Each Unit is Identical 115(W) x 125(L) x 20.6(H) mm / 4.5(w) x 4.9(L) x 0.8(H) in
  • Weight: TX: 353g, RX: 346g
