Headphone out on Macbook pro okay?
Robert Johansson
Hello,
Sorry if this question already been posted.
Is the headphone out on a Macbook pro (late 2015) okay to use for taking measurements with REW?
I mean the frequency response of the 3,5mm output, is it straight from say 10Hz-20kHz or do i need an external sound card if i want correct mesurements??
Best regards,
Robert
MediumRare
You need a proper, calibrated measurement microphone. Almost everyone uses a UMIK USB, costs about $100. You cannot use the built-in microphone for reliable measurements. No need for any output - REW runs on the MacBook. Does that answer your question?
[Edit: see post 6 below for my correct answer to OP]
Flynn
I'm not clear on what you're trying to do. If you want to use the headphone output of a MBP as a source for measuring the sound of an external system, it might be good enough. If you suspect it's not sufficient for whatever reason, you could try one of those USB dongle DACs (like an AudioQuest Dragonfly, but there's a bunch of them out there now), which should be fine.
This is all for objective measurements. Subjectively, the MBP sounds pretty bad.
MediumRare
Here's a measurement: Audibly very close to transparent - you'd need trained ears and the lowest-possible distortion headphones to pick out any issue v. perfection. https://audiosciencereview.com/foru...dio-output-of-a-macbook-pro.18276/post-596549 Of course, the power and impedance-matching with the headphone would be critical. But as an output to an amp/preamp you'd be just fine.
Here's some other data to consider; Archimago says it's audible and he's a very credible source, IMO: https://archimago.blogspot.com/2015/05/measurements-usb-hubs-and-8khz-phy.html
Robert Johansson
Hello,
Thanks for your answers, my question was if the output (3,5mm) is good enough for taking measurements in REW. (SWEEPS)
I will use a calibrated mic, the question was not about the mic, it was about the output and the frequency response of the output on the Macbook Pro 2015. I want to know if the headphone out (3,5mm) has a frequency response that is good enough/straight (10Hz-20k)(20Hz-20k??) or if i need a separate sound card to be able to get correct levels through out the whole spectrum when i measure the response of my system with REW.
I will not use the computer when i listen to music, only for taking measurements with REW.
Can i just use a cable (3,5mm to RCA) straight from my Macbook to my amplifier or do i need a separate sound card? I mean what if the output on the Macbook is -10db already at 40Hz? So basically i want to know the frequency response of my computers output.
Best regards,
Robert Johansson
MediumRare
Hello,
Best regards,
Robert Johansson
I understand what you mean now: You want to send the signal generated by REW to your amplifier, right? The answer is: Yes, it's fine. The audio system on the MacBook is perfectly fine and has flat FR. OTOH, It would be best if you output from USB to a good DAC (no need to spend more than $150 for an outstanding DAC. Check out audiosciencereview.com for a list of tested DACs).
There is another alternative: You can save the REW sweep as a file and play that through your regular source. There's a setting in REW that is triggered by that sweep and then REW measures the output from your speakers. Either method will be perfectly fine for measuring your room for EQ purposes.
Robert Johansson
I understand what you mean now: You want to send the signal generated by REW to your amplifier, right? The answer is: Yes, it's fine. The audio system on the MacBook is perfectly fine and has flat FR. OTOH, It would be best if you output from USB to a good DAC (no need to spend more than $150 for an outstanding DAC (check out audiosciencereivew.com for a list of tested DACs).
Thank you :-)
dsnyder0cnn
Thanks for calling this out. The key, I've found is to do one channel at a time and save a timing reference with the channel you're measuring (Left for Left, Right for Right). You could even burn the sweeps to a CD-R and use an old CD player as a source if you wish. I use this approach all of the time. Works great, as long as REW's measurement parameters exactly match those used to generate the sweeps and it's set to use an acoustic timing reference. Great tip.
DanDan
The Headphone Output on any Mac I have tried has been excellent. They can of course be used as a Line Output.
From Apple: "Headphone: You can use this port as a combination headphone and line-out port. Connect headphones (with or without a built-in microphone), self-powered speakers, or other audio equipment using a standard audio cable with a 3.5 mm metal plug.
Some Macs also support optical digital audio output via the headphone audio port. Use a Toslink cable with a Toslink miniplug adapter or a fiber-optic cable with a 3.5 mm plastic or nylon optical plug. To check if optical digital audio is available on your Mac, see the Apple Support article Play high sample rate digital audio on Mac computers."
Pandaman617
Marantz SR6011 || Denon x3300w || Fisher CA-885 ||
Marantz SR6011
Dayton Audio APA150 x3
Macbook Pro 2019
Emotiva Stealth
Xbox One X || Xbox Series X
Mirage OM-10
Mirage OM-C2
N/A
Mirage Omni 260
Mirage Omni 350
Mirage Omnisat
Mirage Omnisat
Mirage OM-200 x2 Mirage BPS-400 x1
If it helps I’ve been using a mini TOS-link to TOS-link cable with my MacBook Pro 2013 for about 4 years with REW and it produces the same results as my MSI Gaming laptop via HDMI.
