Leon's AV Room Project
L
Leonard Caillouet
Guest
We are just at the deciding to add a room stage. Right now we have a back room that is 23.5 ft by 9.5 ft that is a lanai that was closed in. We are going to open that back up and add on a room to make a large theater and listening room. We can comfortably go back another 20 feet giving me a space as large as 23.5 x 30 ft. The current room has an 8 ft ceiling and that will remain, as one of the things we want is storage room upstairs over that area. The question then is what dimensions to go with, and what ceiling height to use on the rest of the room.
Also, we want to be able to open the room up to the patio is on one side of the addition, so we will need some heavy glass doors and need to get recommendations for something substantial. Obviously there will need to be acoustical treatments on them that can be moved. The room will be laid out with a projector on the wall opposite the glass doors to be able to watch from the screened in patio and hot tub. It may provide for some interesting listening with an open rear wall as well. That dimension is the room width which will be 23.5 ft.
I am open to suggestions, particularly from staff, as this will give us another option for review events.
Peter Loeser
Southwest Michigan
My suggestion is to invite me over to hang out in the hot tub and watch movies when you're done!
This looks like a fun project though. If I understand correctly, if you're in the room looking at the screen, the glass door is behind you?
As far as room dimensions go, I've seen a handful of so-called golden ratios. Your length vs width look ok, although the width is close to a multiple of the height. If you have some freedom in terms of speaker placement plus some acoustic treatment I think you'll be in good shape though. You may be able to use the dimensions of the additional space to your advantage in terms of acoustics, although practically I don't see a reason to go much above 8ft ceiling height in the addition.
How big of a screen are you thinking of installing?
With that size room (and taking into consideration the screened-in porch/hot tub), I might be inclined to go with an AT screen to get a huge image?
L
Leonard Caillouet
Guest
Debating that. I need to get some layouts done to see how it might work. May scrap the idea of being able to view from the patio and just put a smaller set out there. We do want to be able to open up the room to use it for ball games, crawfish boils, etc. so I still need to deal with large sliding glass doors, but there are some pretty nice ones out there that are pretty solid. And the room will be big enough that we should be able to work around it.
Peter Loeser
Southwest Michigan
With necessary light control and some kind of portable acoustic treatment (maybe there's a way to combine the two?) I think any potential issues from the glass doors will be minimal. Even with the sliding doors in place I think I still like the idea of doing a 2nd smaller display outside. Even with a large projected display inside, I'm imagining it being tricky to read small text like scores, tickers, etc. from 30ft away outside. Plus that's a lot of space for bodies to accumulate and block the view.
