Sound room basement
Very small Basement room with concrete outer walls. Ceiling made of acoustic plates. Size about 3,65m X 4,4 m. Height only 2,05 m. Mainly used for stereo listening, but it also contains home cinema equipment
Knut Ø. Mikelsen
Sandnes, Norway
Marantz SR6010, Hegel H160
Hegel H160
Rotel RB995-MKII
Samsung
Audiovector SR3 Avantgarde
Audiovector
Audiovector
Monitor Audi built in
Sunfire HRS-12
Samsung 70"
Knut Ø. Mikelsen submitted a new Showcase Item:
Sound room basement
Very small Basement room with concrete outer walls. Ceiling is made of acoustic plates Ecophon Focus-C. The walls are covered by huntonit plates (a kind of mdf) and they are about 10-15 cm thick on top of the concrete with 7,5 cm Glava isolation. The concrete floor is covered by Berry Alloc plates.
Size about 3,65m X 4,4m. Height only 2,07 m.
Mainly used for stereo listening, but it also contains home cinema equipment.
Equipment use for stereo: Hegel H160 integrated, Audiovector S3 Avantgarde, Sunfire HRS-12, Source is usually Airplay built in to the Hegel streamed from a Macbook Pro or streaming from Tidal.
Home Cinema equipment: Marantz SR6010, Samsung UBD-K8500, Audiovector C-series as surround speakers, Monitor Audio C256-IDC as atmos speakers built into the ceiling.
I have used some acoustic plates to reduce the first reflection from the main speakers. I used the mirror method to find the placement of those. I have not doen anything with the second reflection because I'm not sure if it would be good for the sound.
I have tested with some big temporary Base traps in the back corners of the room. I can't say that I heard any difference.
tripplej
NAD T-777
Oppo 103 Blu Ray Player
2 Paradigm SE Subs
Nintendo Wii U Gaming Console
Samsung UN75F8000 LED TV
Universal Remote MX-450
Thanks for sharing. I liked the room setup. Very comfortable that is for sure. You will have a great time in the sound room. :)
chrapladm
Very nice setup. Looks great. Looks more realistic for me then most other HT setups I have been seeing.:T
AVA Cinema
Yep... you've done quite a bit with a small room there. Hope you continue to enjoy it.
