Subwoofer Placement Advice
Ice32
Audio GD HE-1 MK2
NAD 2200PE upgraded by Peter Williams (Bridged)
Roon
Gustard R26
Polk Ledgend L600
Rythmik L12
Singxer SU-6
Minidsp DDRC-24
I currently have a sub located in the right corner of my room. I will be adding a second sub in the near future and due to space limitations my placement options are left side wall or left rear corner (where it will be partially obscured by my couch). I know about sub crawl and things like that but how much would sound be affected if I place the 2nd sub in the left rear corner? That would be the ideal spot for the 2nd sub.
Wayne A. Pflughaupt
Corpus Christi, TX
Canton Karat 920
Canton Karat 920
Canton Plus D
Hsu ULS-15 MKII
Stock Yamaha Remote
Roku Express
Won’t know until you try, and measure with REW. I haven’t had good results with catty-corner placement like that. But every room is different.
VJM
Bright Side Crew
STL
Opposite corners would be a good start, front right and left rear, the couch obscuring the sub won't be an issue.
But I agree with Wayne, run REW when you get a chance to see and play around with placement.
Peter Loeser
Southwest Michigan
Can you stack the second one on the first? What’s your goal for adding a second sub… more SPL / overhead, better distribution?
Ice32
Audio GD HE-1 MK2
Roon
Gustard R26
Polk Ledgend L600
Rythmik L12
Singxer SU-6
Minidsp DDRC-24
Yes, I could stack them but I'd prefer not to. I'm looking for better distribution for 2 channel listening and more spl for home theater. I use a Schitt Syn to switch inputs, so different systems for each application.
Jack1949
Active Member
Loveland, Colorado
Yamaha RX-A3040
KING 5-CHerry Amp - Digital Amplifier Co.
Oppo BDP-103D
JTR 210RT
JTR 210RM
Ascend Acoustics Sierra Towers with RAAL
Polk Audio RT55i
Polk Audio RT35i
Dual JTR 118HT
miniDSP 2x4 HD
Samsung UN60H6350
Temporarily move your current sub to the left rear corner and give it a listen (or take REW measurements). Then you can decide how much the sound is affected.
whats the size and shape of your room? Is it sealed.. or is the room open to other rooms?
EGR64
Schiit Freya+
Bryston 4BST
Chord Hugo TT2
Dynaudio Evoke 50
RSL SW10
Opposite corner risks having cancellation problems. You'd be better on the sidewall is my guess.
Ice32
Audio GD HE-1 MK2
Roon
Gustard R26
Polk Ledgend L600
Rythmik L12
Singxer SU-6
Minidsp DDRC-24
Room shape is a rectangle. It's 22' X 14' however there is a partial wall at 13' on the left side. The wall is about 6' long and the top of it opens at about 4'.
ManCaveAudio
Have you explored the "Room Sim" in the REW? You can add your room dimensions and sound absorption rate, speaker placement and sub placement and other parameters to check the expected result before you plot 2nd sub in the room.
I was just getting ready to suggest that.
Also, with a room that's basically rectangular, I think you should try one sub in front, one in rear... or two subs at the 1/4 mid points of the front wall. But definitely try the room sim feature in REW.
Ice32
Audio GD HE-1 MK2
Roon
Gustard R26
Polk Ledgend L600
Rythmik L12
Singxer SU-6
Minidsp DDRC-24
Surprisingly the best place for the 2nd sub in my setup is back right corner according to room sim.
While you have a couple of options on placement, which I'd always try to get the best natural response... you also have the DDRC, which has Dirac Live? That should take care of your low end for you,
  • Like
Reactions: VJM
Gerry Iaria
Portugal
Marantz Cinema 50
Sony X800
Arendal 1961 monitors
Arendal 1961 centre monitor
Altec c1
Totem Acoustic Dream catcher
Arendal Sub1- Ken Kreisel 800
Samsung S95C 77inch
yes, L.O.L
Apple
I've tried room sim, but can never understand what it says, like absorption, never know what to set that at
JStewart
Central FL
WRT absorption setting, John M said this: “The coefficients will mainly affect the height of peaks/depth of dips, the overall distribution won't be affected so for experimenting with positioning options the coefficients aren't that important.
Post in thread 'Surface Coefficients in Room Simulation'
https://www.avnirvana.com/threads/surface-coefficients-in-room-simulation.8674/post-66394
natty
One of those available spots likely has better response in relation to the existing subwoofer and the existing subwoofer's location. So life will be easier if you choose said spot (from the available options).
But chances are very good that if you are willing to spend a little time with REW, and use the phase knob on ONE of the subs, that left rear corner spot will work JUST FINE.
Here is a description with examples of how to do that, from https://open.substack.com/pub/hometheater/p/coming-soon
Subwoofer Setup​
Location, time alignment, distance setup, crossover selection, and EQ.​
OCT 9, 2021
This post assumes you are using two identical subs in your room of adequate output*** to achieve your goals. In almost all instances, the quality and accuracy of the bass is better when you split your sub budget in half and get two subs. (Actually, four subs is the sweet spot, but most of the goodness can be achieve by setting up two subs well.)
There are five main steps to subwoofer setup after you have set all your speakers to "small," and are sending the subwoofer signal out of your AVR or pre-pro as a single mono signal**:
  1. Placing the subs (and seats) in the most favorable positions.
  2. Aligning the subs with one another (often called ”time alignment" or "phase alignment.")
  3. Then, aligning the subs with the mains (often called the “distance tweak" since it is accomplished via the distance setting on an AVR.)
  4. And, selecting the crossover points for your speakers. (Repeating steps 3 + 4 iteratively since they interact, until you find the least compromised combined settings.)
  5. Then, running room EQ (and adding a customized house curve, if you like.)
First, one needs to place the subs (and seats) in the most favorable positions.
The concept is that you place the subs as best you can for your given room.
If you have multiple rows of seats, you likely want to place one sub in each corner of a rectangular room. You might be able to get by with two subs, likely in katty corner locations, or the center of two opposing walls. But four subs will give you a more consistent result.
If you have only one row of seats, you can usually manage with just two subs if:
  • you have some placement flexibility on the front wall or the back wall, and
  • you have the ability to move the seating forward or back to avoid dips along the length of the room.
Often, putting those two subs at 1/4 and 3/4 of the front wall or of back wall (both in front or both behind), or in both the corners at the front of the room, or in both of the rear corners, will give you good left/right consistency across seats.
Of course, rooms are not symmetrical even when they measure that way with a tape measure. Different construction, door jambs, etc, make them acoustically not quite symmetrical especially in the bass.
Todd Welti did some great research at Harman on subwoofer placement, which gives you a visual reference for what locations tend to work the best in symmetrical rooms, so if that is what you have, this can get your started. .https://www.harman.com/documents/multsubs_0.pdf
Some subwoofer placement options give you a big head start in terms of getting consistent bass response across multiple seats, typically with fewer dips in response to deal with. Those diagrams give you a head start.
Where to place the seats: If you have the choice, and you have a rectangular room, you can estimate the places most likely to have the best (as in least bad) bass response in the room, so it is worth starting at these locations, if you can. Even if you can place your seats in these places that are likely to be the least bad, there will still be significant problems with your bass response, hence this guide to using multiple subwoofers to dial in your sound more accurately. Anthony Grimani, in his CEDIA training, likes to use this diagram showing which locations are the least problematic.
And now, the short cut: With many modern AVR’s, you may be able to stop at this point and let the AVR do the rest of the setup, alignment and EQ work! It may require using a dedicated sub output per subwoofer, and it may not do as well as the process described below. But it may be enough to get you something acceptable. If not, or if you want the bass to be even more accurate, continue to the next step.
Then, assuming we are chasing excellence, one needs to (time) align the subs with one another.
This creates a single virtual subwoofer, with positive summation (ie, fewer dips and better peaks)andmore seat to seat consistency than a single subwoofer can generate.
You will need to electronically time align the subs to one another. There are many good videos and explanations of thistime alignmentprocess, so I will keep this one relatively short and simple.
The simple version is with two subs.
Level or gain match then with an SPL. Yes there is a difference between these two methods. But either will work. Then time align:
Leave one sub's phase at zero. And adjust the other subs phase until the combined response of the two subs produces the fewest troughs in response and the most consistent response across your seats.If you have a rectangular room, and you can symmetrically place your subs in the room, you may not need to do anything else to time align them together......so if your response from the two subs looks fine in REW, you can skip the rest of this and proceed to steps 3 and 4.
But often, there is improvement to be had. Here is an example where alignment was necessary, because I did not place the subs symmetrically in the room:
I thought I was going to have to bust out the miniDSP for my subs and that would let me adjust the distance even more than the phase knob, but then I remembered that the phase knob on the Rythmik is also a distance knob (even tells you happily what 180 degrees is in milliseconds of delay), and found via the REW alignment tool that about 7ms was what I needed.
Green and Purple are the individual subs.
Red is the combined response without time alignment.
Yellow is the combined response with time alignment.
For simplicity, I do not show all the other traces that didn't look as good as the yellow version.
Pretty text book summation where the combined response meets or exceeds (especially in the critical chest slam 40 to 60hz region) the response of any individual sub by quite a margin, in many cases by more than 10db.
Note that I tried to use the REW time alignment prediction tool. It wasn't quite right. So it pays to take time to experiment with different "distances" or "phase."
If you have more than two subs, once you have dialed in two subs, consider those a single, virtual sub, and then align that single virtual sub with the third sub, and so on, for as many subs as you have.
If you have three or more subs, it can be worthwhile to use a miniDSP and to use the free Multi Sub Optimizer software. This video shows the process with a miniDSP. Personally, I think you can likely do the job with simple phase knob adjustments on many systems. So feel free to use this approach but to adjust “delay” with the phase knob on your sub(s) before going the extra step to use a miniDSP:
Note: In theory, some "room correction" systems are getting better at doing this for your subs. I'll bet if you check their work, you can improve upon them. But those system may be “good enough.”
Finally......check your other seats. If you have significantly different response in your different seats, you mean need to move the subs, some seats, accept imperfect response for some listeners, and/or add more subs.*
The Third & Fourth steps are where one figures out the AVR distance and crossover settings.
These two steps actually interact with one another, so you will work on them iteratively.
One needs to align this single virtual subwoofer (ie, all the time aligned subs as a single sub output) with the mains. In the old days we called this phase alignment, but the normal tool here is the “distance” setting on the AVR.
This was popularized as thesub distance tweak.
To get this right is an iterative process where you measure the response in that region with different delays (distances) for the virtual single sub, and with different crossover points.
You can see quickly that that means measuring every distance from zero to 30ms, with a 60hz crossover, then all those distances again with a 70hz crossover, etc, up to 120hz or even higher. There will likely be a combination that is a little better at showing no wide dips……and that is the best alignment.
Don’t worry about peaks. You will EQ the final result.
And remember: Sometimes the best alignment is using, for example, a 120hz crossover, and that may feel weird…… and sometimes you may do almost as well at 80hz, and that’s okay……..and some people prefer 80hz and choose that lower choice even though it’s not quite as good.
Personally, since that lower frequency choice also increases seat to seat variance in the 80 to xxx region, I find in such a situation that the 120hz crossover in this example might actually be the better compromise. Better alignment with the mains and better (less) seat to seat variation due to the advantage of multiple subs covering more of the frequency range.
The verification will be the REW measurements of the final result showing a positive summation throughout the crossover region. And while it should go without saying, your auto setup software may not choose the best distance nor the best crossover for you. It doesn't actually test the speakers and subs TOGETHER nor with different real world settings. It measures them individually and tries to predict what will work best.
Here is an example of the concepts at work in a real room:
I started with 80hz and checked the distance from 10' down to 0' which is more than a 180 degree phase shift in the crossover region, so should cover most options.
2' of distance was the best compromise. Some were a tiny bit better in the 80hz region, some were a little better in the high 90s, but those involved tradeoffs in one or the other area. 2' was the best balance.
Here is a closeup showing the region a bit better:
Then I tested different crossovers to see what could be gained....And 80hz was still the winner.
Then I tested where things broke down when using the Center speaker instead of the Right speaker as the bed layer speaker I'm integrating the subwoofer with. No worries:
Finally I tested the surround speaker crossover. Going lower than ARC chose (100hz) did create a better graph, but the power handling of the Triad Bronze satellite when trying to play at 90hz was not up to the task. Its a small specialized speaker and just a temporary choice. Bumping the crossover up to 120hz didn't make it worse measuring than when at 100hz, and increased the power handling, so that is what I settled on for this speaker for now. (I'll be eager, short term, to reclaim my on wall Revels for this room, and longer term to use the Triad Bronze LCR for surround duty when I build out the false falls.)
Always remember that the measurement tools can make these differences look really big. But the truth is that audibly, just getting "in the ballpark" will often work very well. That is why the automated systems, even if they aren't as thorough as this iterative process of testing real configuration changes, often can sound good.
What do I mean?
Many of these glaring differences disappear when human hearing is taken into account.....and arguably if one completely trusts psychoacoustic smoothing, 4' might be a better distance setting for the sub than 2' by a tiny margin (ie, 1db in some places). Or, in other words, I have graphed the measurements to exaggerate as much as possible what the microphone can pick up and what the graphs can show, but if you take into account what a human can hear, things are much less stark:
And then Step Five, running your room EQ, will clean things up super well.
You can also add in a house curve if you like, with something like the room EQ app editor (Audyssey makes a $20 app for their system, Anthem Genesis allows you to adjust their curve, etc). Or do it in a miniDSP, even adding a BassEQ system, just don’t re-run your room EQ system with a miniDSP’s house curve in place, because the room EQ system will reverse it!
And, enjoy!
Final thoughts.
There are a myriad variations to the method described here. But the concept remain very similar.
MiniDSP: A popular tool is a minidsp instead of using the phase adjustment on the subs to time align the subs. Some people also like to use the minidsp for EQ to take some of the effort off the room EQ system, or even use the minidsp to align the subs to the mains (distance tweak). And / or they use the minidsp to also apply bassEQ. I have a minidsp and I found I didn’t need to use it, and I wanted to share the process without using one.
MSO: Especially if you have three or more subs, including mismatched subs, and a miniDSP, you can use a free piece of software called the Multi Sub Optimizer to take your REW measurements and figure out optimal settings to align and EQ your subs, that you then dump into your MiniDSP…..resulting in one great measuring single virtual sub.
Tactile response: The gold standard is to generate enough SPL with your subwoofers to hit reference level in the LFE channel, 115db. If you have too large a room, too small a budget, or too little acoustic isolation (where that level of bass is going to disturb other people) you can consider using “tactile transducers” to get the feeling of extreme bass with fewer drawbacks.
Footnotes:
*In addition to my short summary at the start of this process, see also Welti's papers on this, his engineering papers in which he discusses tradeoffs between output and consistency across multiple seats, his interviews like at AVRANT on YouTube, etc.
**Don't fall prey to magical thinking about stereo subs, speaker level inputs, and so on. You don't need to blindly follow any theories, either. Rather, make use of the double blind studies conducted with hundreds of people, that show how a mono subwoofer signal, processed correctly, coming from the right places in the room, is seamless and transparent to the source.....even more than full range speakers, stereo subs, and other kinds of superstition left over from the 20th century, which have no support once listening tests are no longer sighted.
An excellent series of short articles that dive even deeper into this topic of getting good bass:
widescreen-review-bass-management-part-1
part-2
part-3
part-4
part-5
*** I realize that for some people, a single sub is the only option. If this is due to budget, frankly, I'd split the budget and get two lesser subs. But for the sake of completeness, I'll mention that you can increase your chances of decent sound from a single sub with a few simple steps, if you only care about one seat, where a single subwoofer can work okay sometimes. The following is an abbreviated process and assumes you don't want to buy a calibrated microphone and learn to use REW for measurements.
1. Place the sub on your main seat.
2. Then play some “bass sweeps” from youtube orCustom Chirp and Sweep Tones | Audio Test File Generatoron repeat. 10hz to 200hz is enough.
3. Go to the places in the room where you might place the sub. Using your ears or a free SPL meter app on your phone, see what the sweep sounds like from that location.
4. When one of those places gives you a nice smooth bass sweep, that is a good place for the sub. (What does a smooth sweep sound like? Use your ears or an SPL app on you smart phone. You want to see the SPL dip as little as possible. You probably won’t find some place that is perfect. So settle on a place that has the fewest big long deep dips. Even your ears can be enough for this.)
5. That place with the fewest long deep wide dips is where to place the sub.
6. Then run your room correction, and enjoy.
***See the discussion of RP22 for more about output.
ManCaveAudio
The absorption is a property of the material used in your home theatre room.
Like if you have a wooden floor or vitrified tiles in your room, both have different properties for sound absorption and reflection. If your room is well-treated, you have a good amount of absorption ratio.
Material's sound absorption is measured with the sound absorption coefficient, which is the percentage of the absorbed energy to the overall energy formerly transmitted to the material by the sound wave. Every sound/frequency' in your room is absorbed and unabsorbed sound/frequencies bounce back into your room and to your ear eventually.
Please refer: https://www.acoustic-supplies.com/absorption-coefficient-chart/ or https://www.omnicalculator.com/phys...cient#sound-absorption-coefficient-calculator
Gerry Iaria
Portugal
Marantz Cinema 50
Sony X800
Altec c1
Samsung S95C 77inch
yes, L.O.L
Apple
Thank you for your reply, hope all of that makes sense to you, but not for me :) :) :oops:
Ice32
Audio GD HE-1 MK2
Roon
Gustard R26
Polk Ledgend L600
Rythmik L12
Singxer SU-6
Minidsp DDRC-24
Thanks everyone. I was going to get a Rythmik F12 to pair with my L12 but then I saw Mitchco's review of the F18 and off I went. It should ship out on Friday and will be temporarily paired with the L12 until I get another F18 next month. I'm really looking forward to getting it.
ManCaveAudio
Congratulations and happy to help you.
steve138
ANTHEM AVM-90
Linn Chakra 3200x2
Linn Akurate 4200 Centre active and front wides
Linn Akurate 4200 x2 (sides, rears and 4 heights)
Anthem AVM-90
Panasonic 9000
Linn Kaber Aktiv
LINN AV5120 Aktiv
LINN TUKAN (modified & upgraded)
LINN AV5110 (modified & upgraded)
LINN SIZMIK x2, REL Q201E x2
JVC DLA N5 4K/3D
Screen Goo reference White painted
OEM
Linn KLIMAX DS Renew
QOBUZ, SPOTIFY
Sky HD
Magenta TV box (Germany)
I recommend watching the all the webinars by Anthony Grimani (formerly Dolby Labs, THx and his own companies) on Audiholics and AVProEdge Youtube channels. He covers all aspects of Room acoustics and Bass Management including Sub Placement and standing wave control. I designed the Home Cinema in my New House around these principles (Atmos speaker positions, Sub Placement - four, one per corner). and Acoustic treatment plan.
