Comparing my Dali and Klipsch center
Bacovish
Austin tx
Yamaha RX-A1050
Dali Zensor 7
Dali Vokal
Klipsch RP-240s
Paradigm pdr-12
Klipsch RP-280F
Sony XBR 75 940d
Yes, to some aesthetics might be an issue especially in a multi purpose room. Just throwing gunk against the wall.
I appreciate the ideas. I always love doing research and window shopping. I have also been waiting for the new Chane to come out.
JBrax
Marantz sr7010
Emotiva XPA-3
Samsung K8500
PS4
Klipsch rf-7 II
Klipsch rc-64 II
Klipsch rs-42 II
Klipsch rb-51 II
Klipsch rb-51 II
Klipsch rb-51 II
SVS PB12-NSD (X2)
Panamax M5300
Sony Bravia XBR65-930D
Logitech Harmony One
I've never heard the Chane speakers but they've gotten lots of love by members and staff here. There's just so many options out there it can almost get overwhelming at times.
Bacovish
Austin tx
Yamaha RX-A1050
Dali Zensor 7
Dali Vokal
Klipsch RP-240s
Paradigm pdr-12
Klipsch RP-280F
Sony XBR 75 940d
I'm sure I'm over thinking this...but going a different direction. The Dali 3 bookshelf has the same set up as my 7's. I wonder if the dialogue and clarity would be using one or even two as a center.
I know no one can answer this just thinking out loud. Might give Dali a shout see what they think. They were pretty helpful during my original purchase.
ShpongleDMT
Denon AVR 1913
Sony PS4
Definitive Technology 8060HD
SVS PB12-NSD
Samsung Plasma
Since the center is under the TV in a cabinet, is it angled up slightly or facing straight? I have my center similarly place and used a folded towel to angle it up slightly toward my head at the main listening point. Doing so with yours might also help.
Tonto
Yamaha RXV-795a
X-Box 1s
Yamaha S796 DVD Player
Chane A5rx-c's
Chane A2rx-c
A1rx-c's
A1rx-c's
SVS PB13U
APC S15
Samsung Smart TV
What kind of room treatment are you using? Typically, if the room acoustics are not addressed, increasing the gain of the center will not help. It can even exacerbate the problem if reflections are the issue. This is why the Klipsch could sound better. That tatrix horn focuses the sound into a more controlled dispersion which helps with 1st reflections. Is the Klipsch center sealed or ported?
Can you run some sweeps with REW?
Bacovish
Austin tx
Yamaha RX-A1050
Dali Zensor 7
Dali Vokal
Klipsch RP-240s
Paradigm pdr-12
Klipsch RP-280F
Sony XBR 75 940d
It's ported. I don't have a dedicated HT room so it's kinda hard to place proper room treatments and etc. it's a shame. I absolutely love the Zensor towers. I'm not done with the center yet. Sometimes you just have to take a step back and decompress.
tesseract
Lincoln, NE
Emotiva XMC-1
Emotiva XPA-2 Gen 2
Emotiva XPA-3 Gen 2
Dayton SA1000
JTR NOESIS 210 RT - L/R mains
Chase SHO-10 - Center
Chase PRO-10 - Surrounds
Vizio E550VL
Sure, I can answer and possibly save you some money!
Don't double up on the center channel, the two speakers will interfere with each other causing lobing errors (peaks and nulls). Look for one capable center channel, preferably a bit more heroic than the left/right mains. For instance, my mains each have a single 5 1/4" woofer. My center has two 5 1/4" woofers.
Most of the program material will be directed to the center, so it needs to be robust.
