Kerr Forrest
- Sep 21, 2020
- Messages
- 9
**Apologies for the double post but I realised I started this same thread in the non-DIY speaker forum, so if any moderators see this I would appreciate it if you could remove the original in the "SPEAKERS AND SUBWOOFERS > Speakers" forum
I am designing a crossover using Vituix for a 2-way bass reflex speaker design and am somewhat unsure on which woofer frequency response I should import and use when designing the crossover.
I have the infinite baffle response provided by the manufacturer as well as a simulated response I made of the woofer while placed in the bass reflex cabinet using Vituix's enclosure simulation tool. My assumption was to use the simulated in-cabinet response since this is obviously closer to how the driver will actually behave, however I am finding a large (+6dB) boost centred around 50Hz in the crossover simulation response (note that the both the Fs of the woofer and the port tuning is 30Hz). This way not be related to using the in-cabinet woofer frequency response, but it got me wondering this is interfering with the simulation; I am still playing about the the crossover design so it could be something in there which is causing the issue.
If anyone can advise me on whether to use the infinite baffle woofer response or continue with my bass reflex simulated response when designing a crossover in Vituix I would be very grateful.
Cheers,
Kerr.
Cheers,
Kerr.
