Dreaded hum/buzz or ground loop
Mark C Flick
Denon 3805
Acurus A250
Acurus 200X3
Sony PS3
RBH Signature Classic 1266-SE
RBH Signature Classic 661-SE
RBH Signature Classic 66-SE
RBH Signature Classic 1212-SE
Kenwood CT-406
LG OLED55B9PUA
Netflix & Amazon Prime
Pro-Ject Debut Carbon (DC)
An oddity I've noticed lately is a buzz when my Blu-ray player audio is connected to my receiver with an RCA cable. One of these days I'll give up my Denon 3805 but until then, my temporary solution is a Toslink cable. As you can imagine it's not ideal for great audio. So the basics include;
Sony KDL-40S5100
Denon 3805
Acurus A250
Direct TV receiver, also did it with Dish Network Hopper w/Sling.
Thoughts?
billrobbo
It's not a problem we see a lot of here in Oz, most people stateside use something like the Art Cleanbox Hum Remover.
Peter Loeser
Southwest Michigan
Sony KDL-40S5100
Denon 3805
Acurus A250
Thoughts?
When you say you were using the RCA connection, do you mean digital coax, or analog? If you're going from digital coax to TOSLINK I wouldn't expect it to have any noticeable impact on sound quality. Either way your AVR will do the D/A conversion. If TOSLINK elimiates the hum I'd stick with it.
Have you tried using extension cords to plug your gear into some different outlets to see if hum was eliminated?
L
Leonard Caillouet
Guest
Do you have any filtered or isolated outlets? I wonder if there is some leakage in the isolation on that player. Is the player only connected to the receiver or is it networked?
Mark C Flick
Denon 3805
Acurus A250
Acurus 200X3
Sony PS3
Kenwood CT-406
LG OLED55B9PUA
Yeah, not sure. No filtered or isolated outlets. Yes, digital PCM coax. I can definitely hear an improvement in audio quality with the RCA vs. the Toslink but just can't figure why I get the hum/buzz. It is network connected by wifi not hard wired.
Mark C Flick
Denon 3805
Acurus A250
Acurus 200X3
Sony PS3
Kenwood CT-406
LG OLED55B9PUA
Have tried it in multiple outlets and a couple of different homes.
Peter Loeser
Southwest Michigan
I've had success connecting a single wire between the chassis of the source and receiver, or in some cases receiver to sub amp chassis to eliminate ground hum associated with RCA connections. Not the prettiest solution but it gets the job done.
AVA Cinema
I had some noise when we had Dish Network... I inserted a ground lug in the cabling coming into the room, connected a copper ground wire from that lug to the lug on the back of my receiver and it was gone... GONE!
Mark C Flick
Denon 3805
Acurus A250
Acurus 200X3
Sony PS3
Kenwood CT-406
LG OLED55B9PUA
Until I can figure it out I just unplug my Blu-ray player when not in use. Any other ideas out there?
Mark C Flick
Denon 3805
Acurus A250
Acurus 200X3
Sony PS3
Kenwood CT-406
LG OLED55B9PUA
Maybe electrical tape?
Mark C Flick
Denon 3805
Acurus A250
Acurus 200X3
Sony PS3
Kenwood CT-406
LG OLED55B9PUA
No, before I were to do that I think I'd just as soon put that money toward a receiver with HDMI.
Tony V.
Edmonton, AB, Canada
Onkyo TX RZ920
Samson Servo 600
QSC MX1500
Panasonic 220
EV Sentry 500
EV Sentry 500
Mission 762
Mission 762
SVS PB13u
Panasonic AE 8000
Logitech 1100
You said that unhooking the BluRay player gets rid of the hum is the player connected to the network using a wired eithernet connection?
Mark C Flick
Denon 3805
Acurus A250
Acurus 200X3
Sony PS3
Kenwood CT-406
LG OLED55B9PUA
No, it's connected Wi-Fi.
Tony V.
Onkyo TX RZ920
Samson Servo 600
QSC MX1500
Panasonic 220
EV Sentry 500
EV Sentry 500
Mission 762
Mission 762
SVS PB13u
Panasonic AE 8000
Logitech 1100
Have you tried different anologe cables?
Interesting that the Blu-ray player is giving you the issue... I agree with your sentiment, tho. Maybe it's time to upgrade the receiver.
AudiocRaver
Senior Reviewer
North Carolina, USA
Onkyo TX-SR705 Receiver
Phantom Center
NSM Audio Model 5 2-Way (x2)
FWIW, I have used TOSLINK a lot and have been completely happy with the sound. If your system's sound changes markedly going from digital coax to TOSLINK, then I suggest you look closely at any and all changes involved, there might be other factors affecting the sound than just the fiber.
Mark C Flick
Denon 3805
Acurus A250
Acurus 200X3
Sony PS3
Kenwood CT-406
LG OLED55B9PUA
Believe it or not, my BDP does not have a TOSLINK connection. My current temporary fix is HDMI from BDP to TV and TOSLINK from TV to receiver.
If you're okay with that fix... living with it isn't such a bad thing. You could probably invest $500 in a competent receiver (from a place such as Accesories4Less) and gain some convenience. But your audio experience might not change a whole lot...
Mark C Flick
Denon 3805
Acurus A250
Acurus 200X3
Sony PS3
Kenwood CT-406
LG OLED55B9PUA
Yeah, temp fix. Kinda got my eye on and Integra 50.4 for $399 from Accessories4less, seems like a pretty good deal.
Tonto
Yamaha RXV-795a
X-Box 1s
Chane A5rx-c's
Chane A2rx-c
A1rx-c's
A1rx-c's
SVS PB13U
APC S15
Samsung Smart TV
Yamaha S796 DVD Player
I'd replace the Digital Coaxial cable 1st. A tiny short will cause a hum. And can get worse over time.
Have you wiggled the cable to see if it has any effect?
Mark C Flick
Denon 3805
Acurus A250
Acurus 200X3
Sony PS3
Kenwood CT-406
LG OLED55B9PUA
Doesn't matter if it's a Phillips, Monster or $2 cable, they all do it. Wiggling has no effect.
