Help with 35 year old listening room
Jeff Weissert
White Oak, PA.
Denon PRA 1500
Mcintosh MC 60, modified, SS rectifiers
Nelson Pass, Amp Camp 1.6 for HF Horns
Velodyne ULD-18 amp
Denon DCm-340
Altec Voice of the Theater
Velodyine ULD-18
I would look at something more like 244 or Monster Traps and use the Range Limiter. You're looking to get rid of the bass buildup you're sitting close to. The 242's just won't get low enough.. They'll do 1-2k easily all day long but think broader.
I am thinking of getting 4 of the 2'x4' monster traps and place them behind the 6' couch... that will allow a 1' overlap on each side... I wonder if I should tip them a little away from the wall alternately... would that improve the absorption? I will probably make a "bench" for them to sit on as it will be over a long electric baseboard heater... the bench would deflect most of the heat and make a stand for them.
Jeff Weissert
White Oak, PA.
Denon PRA 1500
Velodyne ULD-18 amp
Denon DCm-340
Velodyine ULD-18
Another thought that I had is to use a full range right behind the listening position and the limited ones on either side... maybe use 3 total then for symmetry...
Jeff Weissert
White Oak, PA.
Denon PRA 1500
Velodyne ULD-18 amp
Denon DCm-340
Velodyine ULD-18
Update: Discussed my issue with Glenn from GIK... purchased 4, 2'x4' monster traps with diffusers...
