serko70
 - Marantz SR6015
- Main Amp
 - Rotel Michi X3
- DAC
 - Oppo 205
- Computer Audio
 - Intel NUC
 - Oppo 205
- Streaming Subscriptions
 - TIDAL, ROON
 - Focal Kanta 2
- Center Channel Speaker
 - Linn Trikan
- Surround Speakers
 - Focal Dome Flax
- Surround Back Speakers
 - Focal Dome Flax
- Front Height Speakers
 - Focal Dome Flax
- Rear Height Speakers
 - Focal Dome Flax
 - Focal Sub Air
- Video Display Device
 - LG 65 3D OLED
Yes, AVR only applies the correct delay for your actual distance with that setting due to lower speed of sound it uses. This and REW's sos set up to 300 will suffice.Ok. So if I understand you correctly, are you saying that I should manually convert the actual distance (2,32 meters) to what the AVR thinks the distance is? 2,32 m / 343 m/s = 6,76 ms, so that equals 2,029 m (6,76 ms / 300 m/s)?
Is that the only manual SOS adjustment I need to do?
