Is my MiniDSP Defective?
745Audio
Is my MiniDSP defective? I have the cables physically installed as follows. Reciever LFE to input 1 on minidsp, output 1 to L Sub, and output 2 to R Sub. All the inputs and outputs match on the MiniDSP routing screen on the computer, with what is physically installed. All unused channels/routings are turned off. I noticed no signal (visibly/audibly on the meter output channel 2) going to my R Sub.
I then looked at the other input/output meters on the routing screen, and there is a signal going to output 3 (even though its turned off on the routings). I then unmute output 3, and get signal to my right sub which is physically connected to output 2! Am I missing something? What do you think? Thank you
AVA Cinema
Post some screenshots of your Routing and Mixing tabs ... of how you have it connected and setup when you get no signal to the R sub.
pratul
Johns Creek GA
Anthem AVM 70
Anthem MCA 20
Anthem MCA 50
Monoprice Monolith 7x200
Oppo
M&K S-150 THX
M&K S-150 THX
M&K SS-150 THX
M&K SS-250 THX
Monoprice Caliber
Monoprice Caliber
JVC RS40U
Stewart 120" Greyhawk
ROKU Ultra2
check the xover setting under "output" and make sure it is set correctly. or just bypass them to test. By default the even number outputs are setup to filter lower frequencies.
jan.didden
Another thing to check is whether or not the 'link' settings are checked.
But yes, post screen shots, much easier!
Jan
jan.didden
He must have been connected because he got input and output. It's just that the routing is screwed up.
Jan
