JTR Speakers NOESIS 210 RT Review
Manufacturer & Model
JTR Speakers - NOESIS 210 RT
MSRP
$2499
Link
http://jtrspeakers.com/noesis_210rt.html
Highlights
3 way high-performance loudspeaker, dual 10” woofers housed in a vented enclosure, ultra high-end coaxial compression driver fitted on a large wooden horn with a 60 x 60 coverage pattern.
Summary
JTR's impressive 210 RT loudspeaker has a baseline presentation that's natural and and relatively neutral, creating a listening experience akin to what you'd find at a live concert event. With a super-wide soundstage, the 210 RT delivers an amazing and realistically detailed separation of sound. The JTR Speakers NOESIS 210 RT rates highly and should top a list of considerations for music and home theater needs.
Introduction
JTR Speakers is well known for their heavy-hitting subwoofers and loudspeakers in high-end audio and the pro sound world. While owner Jeff Permanian has racked up many reviews for his hardy subs, no one has yet reviewed one of his extraordinary speaker designs. The focus of this review is to change that, while attempting to articulate the exceptional performance of the NOESIS 210 RT.
The review pair of 210 RT used a matte black lacquer paint finish over a heavily-braced Baltic Birch cabinet (custom finishes are available upon request). Huge footers and gargantuan binding posts are included. The cabinet, along with the drivers and large dual hand-soldered crossovers contribute to a hefty package weighing in at 125 lbs. per speaker. "RT" stands for "Reference Tower," the carefully sculpted horn, exceptional drivers and crossovers providing a reference-level parts execution, with 43" of height fulfilling the tower designation.
Speaking of, the very first item that draws attention is the large 12" x 12" x 8" horn that is seamlessly integrated into the baffle. A closer look inside reveals the ultra high-end coaxial driver beak protruding from deep within the cabinet. The ultra high-end driver claims a mere .02% distortion in the midband (100dB), which is an amplifier's level of distortion. This horn-loaded 2-way coax is physically stepped back, in place and in sync with the woofers, enabling all drivers to be time-aligned at the main listening position (MLP). The coaxial/horn combo handles 500Hz and up, and the dual 10" woofers cover everything below. This, along with the added efficiency of horn-loading, leads to lowered self-noise; the speaker gets out of the way just like a good amplifier should... just like more speakers should.
Installation
Most music listening was with my pre/pro engaged in Reference Stereo mode, sans DSP or subwoofer assist, as the 210 RT tends to ignore the room, is capable of producing low bass, and I really wanted to wring these attributes out. The 210 RT's L/R contribution to my 5.1 system was explored with multi-channel music, videos, and movies.
The speaker's binding posts are huge and will accept any sane and most insane sizes of cabling or consumer-grade connections. The normal-sized spades on my cables did not quite seat fully on the giant posts, but I was able to get them tightly secured. Cabinet knuckle-rap reveals – to my digits – that the enclosure is well-braced and the front baffle is thick.
I have a real-life listening room (not dedicated to AV) that also serves as a living room. It features asymmetrical walls, hardwood floors, coffee table, etc. Some concessions have been made, light flutter treatment, heavy on furniture (I like to entertain), odd furniture placement to accommodate an optimal MLP and Room EQ Wizard used to dial in optimal speaker placement. The 210 RT largely ignores room anomalies. Even in a less than optimal space, you will be paying less attention to the room and more attention to what the 210 RTs are telling you. Room contributions matter less with the JTRs than with conventional speakers.
Listening
One excellent and most useful aspect of the JTRs is the ability to change the soundstage width and steer images with toe-in and out. This is something that any good speaker can and will do, but holes can develop with too much toe-out or spacing, and that is where JTR separates itself from the norm. So big and full is the presentation that huge spacing between the speakers would be required to cause that type of deleterious effect. I’ve heard a pair (this pair, in fact), placed widely apart, fill an audio show conference room, an event I do encourage others to seek out and experience. Big or small, the 210 RT will make your room disappear, bringing you closer to the room or space the musical event happened at.
The horn, coupled with ultra high-end coaxial, contribute to outstanding sound stage and imaging (SS&I) traits that set this speaker apart from most others. Add in capable low-end response and you have an all-in-one package for a great 2.0 system or the start of a fantastic surround system. Want three, five or seven of these in a home theater setting? You have arrived!
No speaker in my room has ever disappeared like this! The 210 RTs are completely disconnected from the sound. Extremely low distortion, super high SS&I qualities, and glorious central imaging leave accompanying musicians etched into their own spaces. The JTRs will have your eyes looking toward the individual sounds, your head will turn too. My room is an average 12' x 16' x 8' space and the JTRs make for sound bigger than this room typically allows. It made my room's walls melt away, bringing me closer to the performance. I've laid ears on many systems in many rooms, most not as good as I have been able to coax out of my lesser room, and the JTRs delivered me closer to my favorite audio experiences because it ignored the faults in my room better than other speakers.
Sideways movement to the left or right of the MLP shifted images on the stage with minimal changes in tonality. And standing up resulted in NO difference in my room; the sound was the same as seated. I've heard all types of high/mid driver technologies – beryllium, diamond, domes, ribbons, and plasma, to name a few – and nothing I've heard etches details in stark relief like annular drivers loaded into a horn.
2.0 stereo impressions aside, some of my listening was done with my subwoofers active. Not that the JTRs are imbalanced, but because I am. My subs have been used with many speakers, painstakingly placed and optimized using Room EQ Wizard, along with subjective tweaks from myself and a few other pairs of ears that I highly trust. The JTRs had no problem keeping up with 96 dB sensitivity subs, even when I remotely advanced the sub level up (+3, 6, 10, or 12 dB...) all the way to lighting my Dayton's SA1000 half-power light more and more with the advancing gusto. Put simply: I'll need a new subwoofer amplifier if I am to keep up with the JTRs. My ears gave out quickly at this insane level and, while I'd like to explore the realm of JTRs rated 2000 watts of power handling, it would not be good for my health in a 12' x 16' room. -20 dB below reference-level is plenty for "normal" people at normal levels. Let it not be said I did not wring these puppies out with what I had! Back in the real world, the quite capable Emotiva XPA-2 Gen. 2 500 rated watts I hit the 210 RTs with is overkill and users can expect to reach reasonable listening levels with just a few watts.
The JTR NOESIS 210 RT hits the available upper echelons of performance in spite of its middling cost of admission. Open and honest, there is nothing closed in or small about its presentation. The only real complaint I could fairly give the 210 RT is that the treble does not have the type of "airy" room response one finds with other types of tweeters, like domes or ribbons, for instance. That's not even a complaint. It is a matter of taste and dictated by preference and design. One design has wide dispersion and uses the room, the other has controlled dispersion and ignores the room. These types are going to interact with the room differently and lend their own flavor to the sound. You can't have it all with any loudspeaker, and the 210 RT is no exception. The trade here is less room interaction and more precise SS&I, which I found lent to a presentation bigger than my listening room. I'll take that trade off all day long. That said, the 210 RT also delivers more focus because the distortion is vanishingly low. People talk about "clean" bass. Welcome to a "clean" midband and treble.
While the 210 RT does not require bass augmentation, it is my opinion that all speakers can benefit from a subwoofer-based bottom octave or so. The JTR’s inherent, genre-setting, lack of distortion is taken even further when bass duties are handed off to properly-integrated sub(s). If you do add bass augmentation, make sure to get a capable sub system that is heroic enough to keep pace with the dynamic swings the 210 RT delivers.
The carefully sculpted 60x60 horn with low distortion coaxial and a superior crossover is the defining factor that separates the 210 RT from the herd. That factor is ideal in normal-sized rooms, helping to avoid room interaction. I have witnessed this speaker fill a couple of very large rooms and have heard it in a couple of small rooms, too, so am confident that the 210 RT will work in any sized room. Do you have a ballroom? The 210 RT will accommodate the need (seriously).
This review has been a long time coming. Not just on my part, even though the 210 RT have been in my home for four-plus months. It is because these speakers have been in the wild, being so good for so long, yet flying under the radar of many audio enthusiasts. Well, let 'em soar, they are worth any audiophile’s consideration. Do investigate a 2, 3, 4, 5, or 7 arrangement, or just enjoy 2.0 super sweet candy, like I did. 2.0 monsters, a must-hear in the four-figure price range, as well as another digit up! SS&I problems? The 210 RT is here (hear) to help! The process is simple. Put yourself in a good MLP spot. Dial in the speakers to the room. Shift yourself left or right, play with 210 RT toe-in. That is all.
Let's dive into what led me to these impressions, shall we? All of these music tracks were streamed via TIDAL.
Music Impressions
Natalie Merchant, Ophelia "My Skin"
has a central image that pops with Merchant’s voice right from the beginning. The piano is the foundation for this tune, its position behind Natalie has ideal depth and focus; the tonality of that instrument is nicely portrayed.
Daft Punk/Panda Bear, Random Access Memories “Give Life Back To Music." This track has many details in the background that are buried in the distortion of lesser speakers. The 210 RT brought out these details, without bringing them overly-forward. They stayed in the back of the soundstage, kind of like real memories, which is what I like to think the artists might have been going for.
"Doing It Right" nails the synth bass, showing me that the 210 RTs stand on their own without subwoofer assistance. Blunt as a 10 lb. sledge hammer, the dynamic bass swings took my breath away. There is zero impression of a one-note bass quality, the midbass notes are noticeably separated from each other. The subtle ringing sound beginning at 2:32 has a nice sustain to it, giving a sense of space greater than my listening room dimensions. The auto-tune vocals had me checking my pre/pro settings to make sure I was in Reference Stereo and not in surround mode with the center speaker playing. I was prompted to do this often with other songs, as well.
Blue Oyster Cult, Fire of Unknown Origin. Queuing up "Burning For You," my all-time favorite song, ever, I found the song's typically light bass guitar line was a little more pronounced than I am used to hearing, which is a very good thing. If only the recording mix brought the kick drum to bear with the same force. Ah well, can’t have it all.
Enjoying what I heard, I leaned into the rest of the Fire Of Unknown Origins album and let it play to the end. Then, TIDAL segued into an album I've not critically evaluated before (Cultasaurus Erectus). While I'm not entirely familiar with this album, it encapsulated a theme with the 210 RT, as I found myself looking for and listening to old songs of yore, ones I've liked but never heard properly.
For one last BOC song, I dialed up “Godzilla." Oh boy, what a treat that was! "Live" feel was had, a you-are-there-type of sound signature delivered in a way that made me feel like I was outdoors, standing General Admission-style, while sitting at home on my living room couch. Permanian’s pro sound experience comes into play when voicing his loudspeakers, that is self-evident with songs like this.
"Danse Macabre Saint Saens" by John Debney had a huge soundstage, pinpoint imaging, frequency extremes explored and fully realized, with equal weight given to both the low frequency and high frequency percussion. That led me to another common 210 RT theme: audible soundstage width that exceeded the speaker's physical placement, combined with stage depth that punched through my front wall. Images sharp as a surgeon's scalpel, a brilliant vivisection laid bare, allowing the listener to “see” all.
Oscar Peterson Trio "You Look Good To Me" the piano took the lead in this song and I could hear accurate instrument tonality, which is an acid test for any speaker aspiring to be high-end. The 210 RT gets a solid "A+" in this regard.
Peter Schilling, Dann trügt der Schein "Major Tom" once again showed the ability of the 210 RT to articulate challenging midbass notes, as demonstrated by the bass guitar as it took over as lead instrument at 0:53 mark, hammered home with the killer fret-climbing riffs. Schilling’s vocals were front and center, bigger than any other instrument on the stage, making itself known as the REAL lead instrument in this song.
Golden Earring, The Continuing Story Of Radar Love "Radar Love" reinforced my initial willingness to cycle through old favorite songs. Live sound realized, I was taken from my room and transported to the event, making me feel "there" from the comfort of my own home.
My last (for the purpose of this review, that is!) 2.0 channel listening demo was Sepultura's “Orgasmatron." This track nailed down one very important JTR impression for me. Jeff Permanian knows bass and builds it into the 210 RT. This song nailed all of the bass cues, especially when it came to double kicks at the 3:43 minute mark. I had to do like I’ve done with most every track
listed here (gotta make sure I heard what I thought I heard!), rewind, listen again and go “WOW!”. Not only deep, but left/right feet kicks were well-delineated. Good job, JTR!
TV/Movies/Concerts Impressions
Two channel TV viewing (Narcos), was cinematic. The staging was just as with music, as it should be, wiiiide with nicely placed images. Switching to 5.1, I integrated the 210 RT into my existing surround system and it proved extremely satisfying. Left and right pans were so large that it made me realize I need a much bigger screen than what I have to do the soundstage justice. Those of you with large acoustically transparent screens will love the scale these speakers are able to create.
Playing Gorillaz Demon Days on DVD in 2.0 had a spacious soundstage, wide and deep. The JTR placed images appropriately, even seemingly inappropriately, shockingly wide on "O Green World." The faux vinyl scratching appeared well outside of the left speaker, almost knocking down the wall!
Next, I watched most of Thor: Ragnarok (Netflix) in 5.1, up until the end when Led Zeppelin's "Immigrant Song" backed the climatic bridge fight. I let the scene play in 5.1, then paused, engaged Reference Stereo on the pre/pro, and watched it again. I was drawn right back into immersion, quickly forgetting that I was watching a movie in 2.0, so much so that I let it go to the end of the show without considering a reversion back to surround sound.
People often ask about the difference between a music-only or theater-only system. What if you can only have one? My final mixed music/movies impression is that, for people squeezed for space or wanting to start out with a 2-channel system as a base for moving up later into surround, the 210 RT is a solid, one-size-fits-all recommendation. A pair gives an audio soundscape that is large in scale, plumbs the depths and hits any SPL requirements one might need. I went on a sans-subwoofer sabbatical at the end of the review period that involved no surround channels or subwoofers for both music and video. Yeah, sure, I missed the first half octave sometimes, but the time coherence was spot on and more than made up for any last little bit of bass energy that might be missing, way down low where a small percentage of actual program material explores. Yes, subs can matter. Yes, they are beneficial when properly integrated. Yes, add subs when needed. The 210 RT helps mitigates the need and most people will not need them at all. The fact that the speaker achieves this distinction at such a low price point places it in a category all to its own. To all of you apartment/condo/townhouse dwellers: look no further. This is a speaker that does it all without the subterranean disruptions that can upset a neighbor (considering sane volume levels, of course). And if you want to cut loose and shake the floor, just crank the amplifier up and enjoy.
With the rig I have, I found that medium/high levels were hit with aplomb and 99% of listening needs were met. For that last 1%, I went to a high pass crossover with subwoofer augmentation simply because the distortion of the 210 RT is so low and the power handling capability is so high, adding biamplified subs takes a good thing and makes it a little better.
Just to prove the prowess of the 210 RTs, I invited a guest over and let his eyes feast on the imposing front end of my media room (which includes dual subs and a center channel). I then secretly fired up the 210 RTs in reference stereo mode and let the sound wash through the room, only to inform my guest that the center channel and subs were OFF. Inevitably, he had to stand up and check for himself. Yes, these speakers are that impressive.
Conclusion:
The 210 RT's basic presentation is natural, laid back a bit, but not so far back as to be excessively recessed. That means the listening position at home emulates what you'd experience a few rows back from a stage at a venue. And that's what high fidelity is all about. Wide as can be, the JTR's had my head turning in an instinctive attempt to focus on particular images that popped in and out of existence in my listening room. Vocals are given their own spotlight separate from other instruments, brought forward in the mix for leads or recessed into the background, as proper imaging on a real-life stage would be. Like I said, the stage is wide and there is a lot going on. Listening to music on the 210 RT is akin to watching video on a huge screen.
Listening to your favorite songs for the first time, the right way, is great fun and that's what these loudspeakers do differently from almost everything out there. Certainly different from anything anywhere near its price. The JTR Speakers NOESIS 210 RT rates highly and should top a list of considerations for music and home theater needs.
JTR Speakers NOESIS 210 RT Specifications
  • Frequency: 38hz-24khz (+/- 3db)
  • Sensitivity: 95db (2.0 volts, free air)
  • Usable Output: 128db (calculated peak 131 – 3db compression)
  • Recommended Amplification: up to 2000 watts RMS (program)
  • Impedance: 4 ohm
  • Dimensions (HxWxD): 43″x12.25″x16.5″
  • Weight: 125lbs
  • Construction: 24mm, 18ply, void free, Baltic Birch
  • Standard Exterior Finish: Matte black lacquer paint
  • Connectors: Binding Post
  • Warranty: 5 year Manufacturer defect
tesseract
Lincoln, NE
Emotiva XMC-1
Emotiva XPA-2 Gen 2
Emotiva XPA-3 Gen 2
Dayton SA1000
JTR NOESIS 210 RT - L/R mains
Chase SHO-10 - Center
Chase PRO-10 - Surrounds
Vizio E550VL
Hey, thanks, Wayne! Looking forward to your visit.
Jack
Active Member
Southern Indiana
Emotiva XPA5
Darid I30
Hafler 220
Oppo
Klipsch KLF10
Klipsch C7
Various
HSU VTF-3 MK5 HP
Panasonic Viera Plasma, 65"
Lots
Thanks for the review Dennis, I have long awaiting same. While I have not heard these speakers, I can agree with how well horns with 2 - 10" woofers in each cabinet can image. Say goodbye to walls and ceilings eh....
tesseract
Lincoln, NE
Emotiva XMC-1
Emotiva XPA-2 Gen 2
Emotiva XPA-3 Gen 2
Dayton SA1000
Vizio E550VL
Thanks, Jack!
This horn works down to a nice, low 500 Hz, a huge contribution to the room's disappearing act.
Jack
Active Member
Southern Indiana
Emotiva XPA5
Darid I30
Hafler 220
Oppo
Klipsch KLF10
Klipsch C7
Various
HSU VTF-3 MK5 HP
Lots
After re reading your review, I have to thank you for mentioning center fill, you are so spot on. Many folks that have hear mine have to walk up and listen to the center channel speaker to believe it is off. Amazing
Kaleidescape TERRA
OPPO UDP-203
Panasonic UB9000
Spotify
GoldenEar Invisa MPX
Quad Array SVS SB16s
JVC NZ8
Sony 65-inch A95L OLED
Sony 65-inch X900F
ZeroSurge 8R15W x 2
ZeroSurge 2R15W x 2
Just an FYI for JTR fans:
Black Friday Sale. Extremely limited quantities.
Noesis 228HT $1249 (Normally $1499+shipping)
Noesis 212HT $1599 (Normally $1899+shipping)
Single 8HT $699 (Normally $899+shipping)
Captivator 118HT $1599 (Normally $1799+shipping)
Shipping included within Continental, 48 state, USA
Sonnie Parker
Music Server
ROON Nucleus One
Turntable/Cartridge
Music Hall Stealth Turntable
Ortofon 2M Blue Cartridge
Kaleidescape
Lenovo X1 Carbon
FireCube 3
Zero Surge 8R15W-1
Zero Surge 2R20W
Wharfedale Super Linton
AVA Cinema
Cables
AudioQuest - Various
THX PixelGen HDMI
Pangea Power Cables
Custom Cables
Network/Internet
C-Spire 1Gig Fiber
Omada OC300 Controller
Omada ER8411 10G Router
Headphones/IEMs
HIFIMAN HE1000se
Unique Melody Mest MKII
Headphone DAC/Amp
Eversolo DMP-A6
RME ADI-2 DAC FS
HIFIMAN Goldenwave Serenade
Whole House System
HEOS System
Home-150 Speaker x6
Samsung S9 Tablet w/ HEOS
Office/Study System
Office System
Dell Precision Computer
Roon Networked
AV Test Room System
NAD M33 Streaming DAC Amp
MartinLogan Motion XT F200
JTR Captivator RS1
miniDSP EARS
Zero Surge 8R15W-1
Zero Surge 2R20W
Dell Optiplex
Roon Networked
Additional Room System
Sunroom System
Zu Audio DW-6 Speakers
Roon Networked
Dish Joey
JVC 37" TV
Cabin System
Onkyo TX-SR805 Receiver
Infinity Primus P163 Speakers
Shield TV Pro
Sony 55" TV
Vinyl Room
Technics SL-1210GR2 Turntable
KLH Model Three Speakers
Zero Surge 8R15W-1
Barn Jam
Soundfield Custom Speakers
Glad to see this review Dennis... and to see the setup. Excellent job!
Maybe we can get a full compliment of Jeff's speakers in my room one day... perhaps during one of our evaluation events. That would be fun.
Classical music? Please don't punish me ... I promise I'll be a good boy momma. I've tried and tried... just can't get anything out of it, but hey... someone is buying it.
tesseract
Lincoln, NE
Emotiva XMC-1
Emotiva XPA-2 Gen 2
Emotiva XPA-3 Gen 2
Dayton SA1000
Vizio E550VL
Thanks, Sonnie!
Give Danse Macabre a listen, it has become one of my favorite songs!
tesseract
Lincoln, NE
Emotiva XMC-1
Emotiva XPA-2 Gen 2
Emotiva XPA-3 Gen 2
Dayton SA1000
Vizio E550VL
Do it! I am going to challenge you to do it without subwoofers. We all know Jeff knows bass, as I said in the review. A pair or more of NOESIS 215RT would fit very well into the Cedar Creek Cinema. :popcorn: :hsd: :surrender:
AudiocRaver
Senior Reviewer
North Carolina, USA
Onkyo TX-SR705 Receiver
Phantom Center
NSM Audio Model 5 2-Way (x2)
I will take the heat for you, Sonnie. I have found enough pieces that I like and that are well recorded to be able to give a fair classical music review.
thomasssio
hi all, is there any way to get hold of the speakers in Europe?
Btw great review of seemingly great speakers :)
tuan nguyen
Nice review! I've been looking (and lusting) at the red 210RT at least once a week for the last year lol. I'm pretty happy with Jeff's older triple 12 and cap 2400ulf... but man, this review is not helping. I've been wondering/thinking if a pair of 210RT would still play well with the triple 12 as a center.
pascalino
philipps ambilight
Where can i buy them in Belgium (europe) and what amplification is the best match for JRT 210 ?
pascalino
philipps ambilight
hi
You have allready found out ? i am interested in buying 210rt speakers for Belgium (europe) Not sure what is the best match for amplification (rega brio?)
greetings,
Kaleidescape TERRA
OPPO UDP-203
Panasonic UB9000
Spotify
JVC NZ8
Sony 65-inch X900F
ZeroSurge 8R15W x 2
ZeroSurge 2R15W x 2
Hi @pascalino , I'd imagine you need to contact JTR direct and order from them. Here's the email: sales@jtrspeakers.com
JTR *might* have a European distributor, but I doubt it. As for amplification, you can drive them with whatever your preferred brand is... at 95dB, they're fairly sensitive speakers. In terms of matching an amp to the speakers - my opinion is that is a personal call. But, someone else may chime in with a different opinion.
Jack
Active Member
Southern Indiana
Emotiva XPA5
Darid I30
Hafler 220
Oppo
Klipsch KLF10
Klipsch C7
Various
HSU VTF-3 MK5 HP
Lots
That is a great idea. I have some Kimber IsoMike and Waldrep AIX Records surround I'd like to hear on the JTR surround system.
I have several AIX recordings in my possession and they are pretty good. They are capable of good surround to a point in that they appear to be recorded as if you are in the band....so to speak. I spoke to Mark about this last time I was at Axpona as I had some problems with placement of instruments that did not match what was on screen. He just kind of indicated that he was going for good sound and he has succeeded at that for sure.
Jack
Active Member
Southern Indiana
Emotiva XPA5
Darid I30
Hafler 220
Oppo
Klipsch KLF10
Klipsch C7
Various
HSU VTF-3 MK5 HP
Lots
I had written off horn or waveguide speakers as being bright and colored. I had mostly heard classic designs from JBL and Altec lansing or Klipsch. I never really liked any of them much, they didn't produce a very good soundstage either. The only thing they did was play loud, but they typically just drove me out of the room.
I have a pair of Klipsch speakers on similar design to the speakers herein being reviewed and I can say that the sound stage these big Klipsch produce is akin to my Dahlquist DQ10's or Elac's I have on hand. I am sorry you did not experience this, but in my room they image for days, some visitors are amazed.
Sorry, back to our regular scheduled program.
Matthew J Poes
If the Klipsch you have are of similar design you jeffs then they aren’t a classic Klipsch design like the corner horn. If they are a classic, give these a listen sometime, they aren’t similar at all.
I actually have some current reference series Klipsch and they are dramatically different from classics klipsch sound and more similar to JTR. Still not the same though. What can you expect for $1000 a pair in a tower. A reviewer friend brought them over because he was curious how they would compare to my Gedlee waveguide speakers. The Klipsch acquitted itself well but they as clearly outmatched.
JStewart
Central FL
@tesseract , looks like you've had them about a year now. Might you have anything to add? Have any of your opinions changed or been re-enforced after all your time with them?
After reading your review all those months ago these speakers still intrigue me.
Jack1949
Active Member
Loveland, Colorado
Yamaha RX-A3040
KING 5-CHerry Amp - Digital Amplifier Co.
Oppo BDP-103D
JTR 210RT
JTR 210RM
Ascend Acoustics Sierra Towers with RAAL
Polk Audio RT55i
Polk Audio RT35i
Dual JTR 118HT
miniDSP 2x4 HD
Samsung UN60H6350
Good questions, I've been wondering about this also and I've had them on my mind since I first read the article. I've been wondering if these would play well with my existing Ascend speakers. But we need to replace the windows in our home, so new speakers are just a pipe dream for now.
tesseract
Lincoln, NE
Emotiva XMC-1
Emotiva XPA-2 Gen 2
Emotiva XPA-3 Gen 2
Dayton SA1000
Vizio E550VL
I am still rocking the 210 RT pair and very happy with them. Listening to more music than ever and even compelled to watch more Netflix and Blu-rays, even though I am not a big TV-watcher. These loudspeakers are the real deal and most of my listening is in 2.0. My impressions from a year ago have only solidified.
tesseract
Lincoln, NE
Emotiva XMC-1
Emotiva XPA-2 Gen 2
Emotiva XPA-3 Gen 2
Dayton SA1000
Vizio E550VL
Well, you know I am also a huge RAAL fan, lol.
The 210 RT soundstage and imaging capabilities is top notch. They will provide a a good L/R anchor for any system. The wide-dispersion RAAL 70-20 XR ribbons will interact with the room differently than the directivity design of the JTR's. That might work pretty well for the center channel, an intriguing idea, indeed. Both are fantastic designs so I can't see it sounding horrible, but there could be a disparity in timbre with pans across the front three speakers. If the system is DSP-corrected, much of that could be mitigated.
Either way, I can not imagine anyone being displeased with the sound of the 210 RT.
Jack1949
Active Member
Loveland, Colorado
Yamaha RX-A3040
Oppo BDP-103D
JTR 210RT
JTR 210RM
Polk Audio RT55i
Polk Audio RT35i
Dual JTR 118HT
miniDSP 2x4 HD
Samsung UN60H6350
Thanks, Dennis.
There's part of me that wished you said don't even think about it cause it won't work. Now you've given me another reason to consider it. I've been thinking of moving the Sierra towers from L/R to surround duty, and replacing them with the 210 RT (and keeping the Horizon center). So far I've resisted because I really like what I have (and because of new window costs), but the what-ifs still nag at me, especially after I first read your article. I knew timbre disparity might be a problem, so I've also been thinking about replacing my Polk tower surrounds with another pair of Sierra towers. But I really like the SQ of the powered 6" woofers in the Polks, which help the mid-bass in my odd shaped room. So at this point I'm not in a rush to make changes, but that doesn't stop me from dreaming.
Thanks for the reply!
Jack
JStewart
Central FL
Trigger finally pulled Monday. 210RTs. Jeff at JTR said about a month. Also a 110HT for center. Surrounds will have to wait for a bit.
tesseract
Lincoln, NE
Emotiva XMC-1
Emotiva XPA-2 Gen 2
Emotiva XPA-3 Gen 2
Dayton SA1000
Vizio E550VL
You got the front stage handled, good job. I need a JTR center! Surrounds are fun, but that front stage comes first. Enjoy, and let us know how it all sounds.
