Ed Zeppeli
- Aug 30, 2017
- 29
Using the file from post-16, I get the best tracking with the woofer inverted and delayed 0.4 ms.
I used a 6-cycle FDW.]
Cheers. Do you mean post #19?
So rather than invert the woofer would I be better off putting the horn back in positive polarity and then delaying the woofer your set amount or would that maybe throw us off in a different direction?
