Marantz CINEMA Series 70, 60, 50, and 40 Receivers Thread
Marantz recently launched its all-new Cinema Series of AV Receivers. We covered the launch at CEDIA 2022:
There Series has 4 different receiver models, as follows:
CINEMA 70
56161
  • Channels: 7.2 – 50 Watts per channel and 4 sub woofer outputs
  • Watts Per Channel: 50w (8 ohm 20-20kHz)
  • Processing Channel with Pre-Outs: 7.2 channel
  • Amplifier Topology: Class A/B
  • HDMI In/Out/8k: 6/1 HDMI input/output, 3/1 supporting 8K
  • Room Correction: Audyssey MultEQ XT32
  • Independent Subwoofer Pre-Out: 2 (parallel)
  • Amplifier: Discrete Power Amp Unit and HDAM-SA2
  • Phono Input: Yes
  • USB Input: Yes
  • Bluetooth Transmission: Yes
  • Radio Tuner: FM/AM
  • Airplay 2: Yes
  • Digital Decoding: Dolby Atmos, DTS:X, IMAX Enhanced, Auro 3D
  • Music Services: Spotify Connect / HEOS for all others (internet radio, etc)
  • Voice Assistants: Works with Alexa, Google, HomePod
CINEMA 60
56163
  • Channels: 7.2 – 100 Watts per channel and 4 sub woofer outputs
  • Watts Per Channel: 100w (8 ohm 20-20kHz)
  • HDMI In/Out/8k: 6/2 HDMI input/output, 3/2 supporting 8K
  • # of audio Zones: 2
  • Headphone Amp: Yes
  • Phono Input: Yes
  • USB Input: Yes
  • Airplay 2: Yes
CINEMA 50
56164
  • Channels: 9.4 – 110 Watts per channel and 4 sub woofer outputs
  • Watts Per Channel: 110w (8 ohm 20-20kHz)
  • Processing Channel with Pre-Outs: 11.4 channel
  • HDMI In/Out/8k: 7/3 HDMI input/output, 7/2 supporting 8K
  • Room Correction: Audyssey MultEQ XT32, and Dirac Live Upgradable
  • Independent Subwoofer Pre-Out: 4 (independent)
  • Phono Input: Yes
  • USB Input: Yes
  • Airplay 2: Yes
CINEMA 40
56165
  • Channels: 9.2 – 125 Watts per channel and 4 sub woofer outputs
  • Watts Per Channel: 125w (8 ohm 20-20kHz)
  • Phono Input: Yes
  • USB Input: Yes
  • Airplay 2: Yes
This thread is for discussion about the entire CINEMA Series!
Robert Zohn
Scarsdale, NY
Marantz AV8802A
Marantz MM8077
Marantz MM7055
Panasonic DMP-UB900
Sony SS-NA8ES
Def Tech DI 6.5R
Def Tech DI 6.5R
Def Tech DI 6.5R
Def Tech DI 6.5R
Velodyne DD18
OPPO UDP-205
MX-990
Email or PM me if you want to attend in person for Marantz's 70th Anniversary Event on July 12th, 2023 from 11:00 AM to 7:00 PM at Spring Studios, 6 St Johns Ln, New York, NY.
Gerry Iaria
Portugal
Marantz Cinema 50
Sony X800
Arendal 1961 monitors
Arendal 1961 centre monitor
Altec c1
Totem Acoustic Dream catcher
Arendal Sub1- Ken Kreisel 800
Samsung S95C 77inch
yes, L.O.L
Apple
I have the Marantz Cinema 50, had it since last year, so far I'm enjoying it, have a 7.2 system, what do you think of yours so far?? still like it?? let us know :T
