Measuring capacitors and inductivities not related to speakers
redmountain
Thank you John
smothing seems to help
I'll check imp measurements again when I am back home
:T
luigi57
Why impedance measurement graph higher value is limited to 1KOhm?
I'm measuring an MC step-up transformer and by scrolling cursor impedance maximum is more than 16KOhm, Is there a way to increase the maximum Y axis value in order to see the complete curve on the graph?
In the left hand measurement view, the impedance curve is showed cormpletely inside the graph...
redmountain
I get inconsistent impedance measurements even after following tips here...
also the component model isn't always the same, sometimes a series resistor and a coil in series,
sometimes a parallel resitor in parallel to the coil, and another series coil in serie...
The cabling is shielded, measuring ferrite coils from 10 mHy to 2.5 Hy
Using a Macbook Pro mid 2012 's headphone out and line in
Line in impedance is set - like default - in REW : 20'000 ohms
Also the phase graph shows noise in the higher frequencies
  • Impedance measurement component model available.mdat
  • Impedance measurement component model not available.mdat
trobbins
Australia
Perhaps limit upper frequency to 10kHz in sweep.
For a simple loopback using those out/in ports, do you get flat line responses?
