I believe my projector was at 19'.
That ratio will definitely work nicely in your planned space Ron. I'm also very close to Sepmeyer C with my build, which is similar to the Cardas cuboid ratio.
Hard to answer until you try it. My gut feeling is if you can get close to a recommended ratio for a cubic room, you won't gain much more by going with a trapagon once you've applied appropriate acoustic treatments (which you'll want regardless of room shape IMO).Thanks for the link Sonnie. I put in a little bit bigger for the room to get me a 32' length...14x22.4 for the front wall... now I want to see if I can do the Cardas Golden Trapagon ratio from that to help with the modes. I am hoping that the angled walls will eliminate some of the electronic adjustments in the room making it easier on the processor to tune. Do you think this is a good idea?
I really like the layout you are doing with the angled side panels, and I hope to be able to do something similar, but if I angle the side walls...it might give me the same effect.That ratio will definitely work nicely in your planned space Ron. I'm also very close to Sepmeyer C with my build, which is similar to the Cardas cuboid ratio.
It certainly adds some extra work to the construction, though in your case with the clay/brick structure I'm not sure to what degree. I guess all I'm saying is if you can build a cubic room with optimal ratios the extra benefits of a trapagon may not be worth the additional cost/effort. I've not seen a real world comparison two comparable systems in a cubic and trapagon room. If you have the time/space/funds/patience to do it, I really can't see a reason not to try it. I'd love to see it done, if for no other reason, than a proof of concept. If I had more space and a more relaxed budget I would have given it more consideration.So if you were doing a above ground theater build from scratch...you wouldn't go with the Trapagon ratios?
I haven't completely decided yet, but I may make the angled wall sections (or at least portions of them) from AT fabric with speakers and acoustic panels behind them, giving a very clean look to the interior of the room. At the very least it should provide some diffusion of side reflections. I'll still plan to treat what would be the first reflection points, and probably around/behind the surround speakers too. Then go with more diffusion toward the back of the room. Lots to decide still.I really like the layout you are doing with the angled side panels, and I hope to be able to do something similar, but if I angle the side walls...it might give me the same effect.
To expand on my decision, since we'd already have to frame a cubic room I'd be doing double work in some cases. Sort of a room inside a room. Plus, like I mentioned, it wouldn't leave me enough width in the middle of the room where we'd need to walk around seating.
I would not seal the conduit... it should be open from behind your equipment all the way to the speakers so that you can run new wire if never needed. You won't lose any soundproofing via conduit.How do you seal the conduit off when you run Cables? I am asking this to maintain the room being as soundproof as possible.
You could stop up one end with a rag if you want to keep air flow down... but you can't seal it permanently in case you ever need to pull new cables.
