Onkyo Unveils Its TX-NR676 and TX-NR575 Midrange Receivers; Reveals Dolby Vision Plans
Onkyo
(April 7, 2016) Onkyo recently unveiled its second round of 2017 AV receiver releases with the announcement of two new midrange models. The new TX-NR676 and TX-NR575 are both 7.2-channel models, priced $649 (MSRP) and $549 respectively.
Both receivers are nearly identical in total functionality and performance, with the primary exception being amplifier power. The more powerful TX-NR676 is rated at 100-Watts per channel (8 Ohms, 2 channels Driven) versus the TX-NR575 which can output 80-Watts per channel. Onkyo says that proprietary non-phase-shift amp circuitry assures imaging clarity with low distortion, even when the receivers are taken to reference volume levels.
Internally, the receivers carry 32-bit DSP chipsets paired with high-quality AK4458 384 kHz/32-bit DACs and proprietary Vector Linear Shaping Circuitry (VLSC) filtering, all intended to offer a smooth audiophile experience. Hi-Res audio compatibility includes 19 kHz/24-bit FLAC, WAV, AIFF, ALAC, and DSD 5.6 MHz/2.8 MHz). Owners can also tap into Internet radio and streaming services such as TIDAL, TuneIn, Deezer, Spotify, and Pandora. Chromcast, Wi-Fi, and Bluetooth functionality provide additional wireless conveniences.
Both the TX-NR676 and TX-NR575 ship with onboard support for Dolby Atmos and DTS:X immersive sound codecs. Legacy codecs can be up-mixed by either Dolby Surround or DTS Neural:X, elevating standard multi-channel formats to incorporate height channel playback. The included AccuEQ room calibration suites include AccuReflex technology to help correct for phase issues associated with Atmos module speakers.
A look at the backside of the TX-NR 575
Owners will enjoy full 4K video functionality, with coverage for both HDR10 and Dolby Vision. Of course, this includes the ability to pass-through BT.2020 color and HDCP 2.2 copy protected streaming video. One minor difference between the two models is the TX-NR676’s seven (versus six) HDMI inputs, in addition to the ability to output video to a projector and television display simultaneously.
Using onboard FireConnect, owners can link up to four FireConnect capable wireless speakers for multi-room audio playback. This technology allows any connected source, including analog sources (such as a turntable), to be distributed to associated wireless speakers.
As for Dolby Vision, Onkyo announced it will offer Dolby Vision support for select models from its 2016 lineup of 7-, 9-, and 11-channel receivers. This includes models ranging from the TX-NR575 to the PR-RZ5100. Owners can expect to unlock Dolby Vision on their receivers by installing a firmware update scheduled to be released later this year.
Look for the TX-NR676 and TX-NR575 to hit store shelves during May 2017. For more information, visit Onkyo by clicking here.
TX-NR676 Key Specifications
Weight:
27.6 lbs
Dimensions: 21 1/4" W x 10 1/4" H x 17 11/16" D
Power Output: 100 Watts per Channel (20Hz-20kHz,.08%THD@8ohm 2ch Driven)
HDMI Input / Output: 7 In / 2 Out
Front USB: Yes
Analog Inputs: 6 Inputs
Digital Audio Inputs: 2 Optical, 1 Coaxial
Phono: Yes
Channels: 7.1 (5.1.2)
Audio DACs: AK4458 384 kHz/32-bit DAC
Music File Playback: 192 kHz/24-bit ALAC, AIFF, FLAC, WAV , Dolby TrueHD
Dolby Atmos: Yes
DTS:X: Yes
TX-NR575 Key Specifications
Weight:
20.7 lbs
Dimensions: 17 1/8" W x 6 13/16" H x 14 7/8" D
Front USB: Yes
Phono: Yes
Dolby Atmos: Yes
DTS:X: Yes
Asere
Texas
Denon AVR X4200W
Parasound HCA 1500A
Oppo 103D
SVS Prime Towers
SVS Prime
SVS Prime Satellites
Proficient
Proficient
Samsung PNF8500
60"
Harmony Ultra
Glad to hear Onkyo has the new line up. Audyssey or not they do make great receivers.
Tony V.
Edmonton, AB, Canada
Onkyo TX RZ920
Samson Servo 600
QSC MX1500
Panasonic 220
EV Sentry 500
EV Sentry 500
Mission 762
Mission 762
SVS PB13u
Panasonic AE 8000
Logitech 1100
I actually think Onkyo may be on to something with not applying EQ to the front two channels. I will be writing something up about my thoughts later on that point on this forum.
In talking with Onkyo contacts over the last year or so, they certainly seem to indicate that Audyssey was overkill for the vast majority of their customers.
I'd like to see manufacturers concentrate more on low frequency EQ, personally...
