No single answer for ASIO I'm afraid. It can be a bit finicky.
I've had good luck with making sure HDMI is connected and windows is reporting connected to AVR before opening REW.
Next you can open the ASIO control panel in REW preferences and check the connection to the AVR which is usually going to be the HDMI display card/adapter.
In this pic you can see the ASIO control panel and by hovering on the device (Intel Display Audio), the reason it's not connected. In this case it's correct, because I have a music player connected via HDMI and ASIO at the moment.
You're using a miniDSP, right? If that's correct and you're using MSO "Sub-Only" procedure, and ASIO refuses to work, you can get your MSO measurements using the JAVA drivers by:
1. TURN OFF THE POWER TO SUBS, MINIDSP AND AVR WHILE CHANGING THE CONNECTIONS
2. Connect the miniDSP to either the right or left speaker PRE-AMP OUTPUT AND DISCONNECT THAT SPEAKER on AVR. (the other will be used for timing reference.)
3. Set the fronts to "Large" in the AVR.
4. Follow MSO instructions from here.
