Problem with Save Filter in AL 6.20
clarus
When saving filter, AL would ask you to choose the sample rate to support. I usually select the 6 that I used: 44.1, 48, 88.2, 96, 176.4, 192. I generate it in both alc and zip.
My recent attempt seems to indicate that something is corrupted. When I playback at 176.4kHz/192kHz, something is out of phase. There is no more imaging and just diffused sound. Other sampling frequencies seems to work fine. I did noticed that when it was saving filter, the status bar at the bottom would normally show progress for every single sampling frequency. In this case, it will skip over 96kHz, and get stuck at 176.4kHz for like 20+ seconds before going onto 192kHz. It may have skip over the 96kHz because the measurement was taken at 96kHz and the filter has already been generated. The problem is applicable to both alc (when used with Convolver) or zip (when used with Roon).
I experienced this "out of phase" problem before but was able to work around it by resampling to a higher frequency, since the problem usually occur at 44.1 or 48kHz. But this time the problem happen at 176.4kHz (which all my DSD files are resampled to) and 192kHz.
I have tried both 32-bit float and 64-bit float filter format and the result is the same.
juicehifi
Audiolense
The issue you are addressing is a general problem. When you save the filters for many rates in Audiolense, the filter length stays the same. This can become a limiting factor at very high sample rates, with unintended effects.
You can probably get around this by upsampling the measurement to 192 kHz before you create the corrections. Filter lengths and correction settings that work at 192 kHz will in most instances work equally well at lower rates. You may need a longer filter and possibly different settings for a good result at 176 and 192 kHz. When you see good result at the highest sample rate you should get good results for the others as well.
For Audiolense convolver I recommend that you only save for the sample rate that was used during measurement. The convolver will resample the filters, and their sonic behavior will be practically identical at all rates * except for the band with differences associated with each sample rate. If you e.g. make 65 k long filters at 48 kHz you will get 260 k long filters at 192 kHz. The convolver can handle such lengths with ease. Max filter length in the convolver is 65 k * 16. This is unlikely to be a limiting factor before the sample rate goes well above 1 million Hz.
It is a weakness in Audiolense that the generated filters don't have the excact same behavior at different rates, and that the behavior at all rates are not shown. You can, however open and examine the generated corrections. Most of the time you will see anomalies in the frequency response if something has gone wrong. Nevertheless I am contemplating whether to reample the correction filters in Audiolense, as it is done in the convolver. This will sometimes lead to arbitrary filter lengths and/or excessively long filters, and I am not sure how the various 3rd party convolvers will handle either.
Come to think of it; I will add such a variable-length resampling as an option and an alternative to the existing solution.
clarus
Does it mean that ideally, I should do a measure at each sampling frequency and generate a filter for each measurement? For Roon zip file, I could combine the individual cfg and wav files. How about alc file?
juicehifi
Audiolense
Cfg:
It means that you need to check that the correction procedure works for the highest sample rate. I doubt that there is anything to gain by measuring at all rates.
Alc:
create correction for one rate and let the convolver resample the filters.
whoareyou
Benchmark AHB2
ATI AT525NC
JRiver
Exasound E38
Psb synchrony one
PSB synchrony one C
Revel m105
For me, I think this explains what I hear with resampled SACD playback at higher bitrate playback and AL filter (352.8 converted SACD via JRiver).
With AL filter at 352.8 it sounds as if I lose definition in the high end. Converting to lower sample rate, I eventually noticed when I resampled SACD to 48khz (same as measurement) everything sounded "right" to me, so that's rate I always use for listening. I couldn't tell difference between 48 and other slightly higher rates, so I settled for using that rate since it's a bit easier on the processor.
Now, after reading this I decided to see what my simulations look like at 352.8. I resampled my measurement to 352.8 and regenerated with current filter. Simulation now shows the frequency response with big drop at the higher frequencies (Guess only way I can validate is with a measurement, but I'm too lazy so I'll go by my ears with this one).
Other resampled higher rates, up to 192khz) mostly worked with the existing filter, but for 192 one small change to disable the "Prevent Treble Boost" option was required.
For me, simply increasing the filter length (over 192) did not fix the higher frequency dip.
If I am doing this correctly, this seems to explain what I am hearing. Otherwise.....
clarus
I want to add to this thread after more testing. Starting with 192kHz sample rate measurement.
I generated 2 sets of filter using the same parameters. I have maxed out the filter length to 128K. One for Roon, one for Audiolense Convolver.
Using Roon, I have no problem at any sample rate.
Using JRiver + Audiolense Convolver or Streaming with Convolver, I have out of phase issues at 176.4k and 192k. Lower sample rates are fine.
juicehifi
Audiolense
I doubt that your problem is in the convolver, @clarus. It is oblivious to sample-rate and is very fast, which is the only thing that matters for handling very long filters at high sample rates.
Badbruno
ExaSound S88
Polaris Audio
Polaris Audio
Polaris Audio
Mac mini and IMac 27
ExaSound S88
VPI Prime turntable
Custom open baffle 3 way
Velodyne DD12+
Roon
Roon Quobuz
I’m have the same problem with saving my filters with 6.20. I was told that the glitch was solved with 6.21. The application crashes. When I select just two sample rates 48 and 96 kHz it finishes. When I unzip the file there are two 48khz .CFG and two 96khz files?
Advice pls ?
Badbruno
ExaSound S88
Polaris Audio
Polaris Audio
Polaris Audio
ExaSound S88
VPI Prime turntable
Velodyne DD12+
Roon
Roon Quobuz
Sure …When saving filter, AL would ask you to choose the sample rate to support. I usually select the all of them to try with HLC: 44.1, 48, 88.2, 96, 176.4, 192kHz, 352.8kHz, 384kHz for Roon and zip. During the filter writing process AL doesn’t complete the process. The application gets stuck without progressing or the application terminates. To get it to write some files I’ve Only been asking for 48 and 96khz which AL completes. When I unpack the Zip to load into my convolver there are two sets of .cfg files , two 48khz and two 96khz files.
Badbruno
ExaSound S88
Polaris Audio
Polaris Audio
Polaris Audio
ExaSound S88
VPI Prime turntable
Velodyne DD12+
Roon
Roon Quobuz
I would also mention my system is 8 channels, 3-way and two subwoofers
juicehifi
Audiolense
Send me a measurement where this happens and I will take a look.
Badbruno
ExaSound S88
Polaris Audio
Polaris Audio
Polaris Audio
ExaSound S88
VPI Prime turntable
Velodyne DD12+
Roon
Roon Quobuz
  • Naples3way_subV2.zip
  • Carl_3_way_with_sub_V2_28_Mar_23_17_16best.zip
Badbruno
ExaSound S88
Polaris Audio
Polaris Audio
Polaris Audio
ExaSound S88
VPI Prime turntable
Velodyne DD12+
Roon
Roon Quobuz
whoareyou
Benchmark AHB2
ATI AT525NC
JRiver
Exasound E38
Psb synchrony one
PSB synchrony one C
Revel m105
Hi, was wondering if a decision was made to implement proposed AL functionality that would "resample the correction filters similar to AL convolver"?
juicehifi
Audiolense
Yes, it will come. I will try to squeeze it in before the summer holiday sets in. But I’m afraid I can’t guarantee anything before the summer is behind us.
whoareyou
Benchmark AHB2
ATI AT525NC
JRiver
Exasound E38
Psb synchrony one
PSB synchrony one C
Revel m105
Hi @juicehifi
Any updates for resample improvement (and other suggested enhancements) that were mentioned over past year?
juicehifi
Audiolense
I am having a very busy autumn this year on my teaching job, so I haven't gotten around to it yet. But it is on the to-do-list.
