- Apr 3, 2017
- 8,435
In that case you will need to manually calibrate the SPL reading.
with ASIO driver, the UMIK Micro don't appear in the input list, it appear only with java driver
See attached file my flexASIO configuration file. Could you give me the configuration line to override default Windows audio devices .I already declared UMIK - 1 as input device
Glad I found this thread as REW and ASIO4All used to work fine but the last time I used it HDMI did not show as an option so I had to use java so that i could use my umic1 as an input
Today I am trying to run REW again but the same issue exists so I can only do R/L
I can play 7.1 using windows through my Denon and have video to my projector so the hardware seems fine
So my question is what is the route cause ?
Is it an easy fix .
