REW EXCL help
ken996
Marantz 7010
n/a
n/a
n/a
OPPO
NA
Martin Logan
Martian logan
Martin Logan
Martin Logan
Martin Logan
NA
two SVS SB 4000
NA
NA
LG 65 OLED
NA
I have tried everything to get EXCL to work with REW on my windows 11 Lenovo lap top
Im able to get sweeps etc as long as don't try Java with EXCL I am using a Anthem 70
i have tried all the setting for my sound card but still after hours and hours i can not get to sweep to other channels
even though windows is set to 7.1
If i do a test through windows i do get a test tone to other speakers but not through using REW
Is this a common problem with some lap tops? others have said their window 11 laptops work just fine using Java EXCL
What can i be doing wrong ?? i don't have another lap top to try
l
phofman
Does it work with FlexASIO for you? If so, we can generate debug logs by FlexASIO and the WASAPI-excl java library and compare the channel mask used.
Please attach the file which is produced when you use the option to "Generate debug file" on the REW soundcard preferences, with everything connected as you would set it up for measuring.
ken996
Marantz 7010
n/a
n/a
n/a
OPPO
NA
Martin Logan
Martian logan
Martin Logan
Martin Logan
Martin Logan
NA
two SVS SB 4000
NA
NA
LG 65 OLED
NA
John
thanks for your help
Here is the file you asked for
I am not tech savvy at all but have been running REW for a while now with no issues
still earning though
I just cant get to access the 7 channels to do any sweeps
I don't know much about ASIO4all
i down loaded the file but cant program the REW sound card property to get it to work
I hope mine is no one of them as its less than 1 year old
  • soundcard_debug.txt
ken996
Marantz 7010
n/a
n/a
n/a
OPPO
NA
Martin Logan
Martian logan
Martin Logan
Martin Logan
Martin Logan
NA
two SVS SB 4000
NA
NA
LG 65 OLED
NA
I am not tech Savvy at all
I don't know how to set up ASIO4ALL or the new FlexASIO
It would be great if i could get someone to Team View in to help and guide me through setting it up
And I'm not looking for a FREE BE i realize time is money and education is not cheap
It is a little difficult to follow your posts.
The debug file looks fine, there should not be any issue using EXCL: AVM 70 as the output device.
You said "Im able to get sweeps etc as long as don't try Java with EXCL". Do you mean you get no output from any channel when using EXCL: AVM 70, or you can get output from L & R but not other channels?
Set the Anthem's listening mode to None.
Attach a screenshot of your REW soundcard preferences (open the REW soundcard preferences and press Alt+PrtSc to copy the preferences screen to the clipboard, then use Ctrl+V to paste it into your post).
ken996
Marantz 7010
n/a
n/a
n/a
OPPO
NA
Martin Logan
Martian logan
Martin Logan
Martin Logan
Martin Logan
NA
two SVS SB 4000
NA
NA
LG 65 OLED
NA
Settings look fine.
ken996
Marantz 7010
n/a
n/a
n/a
OPPO
NA
Martin Logan
Martian logan
Martin Logan
Martin Logan
Martin Logan
NA
two SVS SB 4000
NA
NA
LG 65 OLED
NA
while using REW Java EXCL i cannot sweep
to any channel
but if i dont use the EXCL selection everything works fine but
i can only sweep to the FT left and rigt channels
ken996
Marantz 7010
n/a
n/a
n/a
OPPO
NA
Martin Logan
Martian logan
Martin Logan
Martin Logan
Martin Logan
NA
two SVS SB 4000
NA
NA
LG 65 OLED
NA
Settings look fine.
while using REW Java EXCL AVM 70 i cannot sweep
to any channel
i can only sweep to the FT left and right channels
ken996
Marantz 7010
n/a
n/a
n/a
OPPO
NA
Martin Logan
Martian logan
Martin Logan
Martin Logan
Martin Logan
NA
two SVS SB 4000
NA
NA
LG 65 OLED
NA
Very odd. Worth trying FlexASIO. The installer is here. Instructions to set it up are on page 40 of Jerry's guide.
John
thank you for your time in replying back
Good news everything works great with using FLEXASIO
I don't know why Java with EXCL wont work on my laptop and i could not use ASIO4ALL either
If you find a cure please let me know as there must be others with the same issue
I cant be the only one.
thanks again
ken996
Marantz 7010
n/a
n/a
n/a
OPPO
NA
Martin Logan
Martian logan
Martin Logan
Martin Logan
Martin Logan
NA
two SVS SB 4000
NA
NA
LG 65 OLED
NA
  • soundcard_debug.txt 2flexasio.txt
No, for the FlexASIO log close REW and do this:
Create an empty file (e.g. with Notepad) named FlexASIO.log directly under your user directory (e.g. C:\Users\Your Name Here\FlexASIO.log).
which means open Notepad, don't enter any text, and then save that notepad file as C:\Users\Your Name Here\FlexASIO.log. Then start REW up again, make a measurement and close it. That FlexASIO.log file will now have a lot of debug info it, so please attach that.
One more thing, after the log has been captured rename the file to something else so FlexASIO doesn't keep logging.
ken996
Marantz 7010
n/a
n/a
n/a
OPPO
NA
Martin Logan
Martian logan
Martin Logan
Martin Logan
Martin Logan
NA
two SVS SB 4000
NA
NA
LG 65 OLED
NA
ken996
Marantz 7010
n/a
n/a
n/a
OPPO
NA
Martin Logan
Martian logan
Martin Logan
Martin Logan
Martin Logan
NA
two SVS SB 4000
NA
NA
LG 65 OLED
NA
I hope this is whats needed
ken996
Marantz 7010
n/a
n/a
n/a
OPPO
NA
Martin Logan
Martian logan
Martin Logan
Martin Logan
Martin Logan
NA
two SVS SB 4000
NA
NA
LG 65 OLED
NA
ken996
Marantz 7010
n/a
n/a
n/a
OPPO
NA
Martin Logan
Martian logan
Martin Logan
Martin Logan
Martin Logan
NA
two SVS SB 4000
NA
NA
LG 65 OLED
NA
ken996
Marantz 7010
n/a
n/a
n/a
OPPO
NA
Martin Logan
Martian logan
Martin Logan
Martin Logan
Martin Logan
NA
two SVS SB 4000
NA
NA
LG 65 OLED
NA
  • flexASIOkenb.txt
phofman
@ken996 : Thanks, that's the right flexasio log. However, it shows your FlexASIO is not configured for the exclusive mode. That means the audio data go through the windows audio subsystem, just like in the java case (not EXCL). Please switch flexasio to exclusive in its config and re-test.
To do that you will need to change the FlexASIO control panel driver selection to WASAPI then tick the box that appears for exclusive mode.
ken996
Marantz 7010
n/a
n/a
n/a
OPPO
NA
Martin Logan
Martian logan
Martin Logan
Martin Logan
Martin Logan
NA
two SVS SB 4000
NA
NA
LG 65 OLED
NA
If FlexASIO works OK, the debug logs are needed to compare.
Please provide logs as per https://github.com/dechamps/FlexASIO#logging while REW starts and runs through FlexASIO, and as per https://www.avnirvana.com/threads/v5-20-10-early-access.10787/post-82326 when REW starts and playback runs through Wasapi EXCL. Thanks.
ok john i reset the driver to WASAPI and checked the exclusive box
Now the sweep noise sounds very strange a low kind of raspy noise nothing like before
is this normal ?
  • flexASIOkenb.txt
No, but it might be related to the FlexASIO buffer setting. You can set that to 4096 to see if it fixes it.
