- Apr 3, 2017
- 8,357
Impulse graph axis can be switched between % and dBFS via the dropdown in the top left corner of the graph.
Yes.if one is modifying the impulse in some way (for example "db + phase average", or "1/A", etc.), and then the impulse looks significantly more like an "acausal" one (compared to the one preceding the modification), then one has probably generated a "problematic acausality"
Many many thanks again!...Yes.
That only moves the IR, it doesn't change it.But what about the "estimate IR delay" function?
REW is an OK oversampler but not on a par with commercial applications.I'm using REW also to convert the sample rate of some external impulses
That only affects graph generation.things like "IR oversampler"
That only affects new sweep measurements.what about the "Truncate IR after..."?
That would suggest the ref time was not at the peak.I've noticed that if I apply the same window (and ref time), and then export applying that window, the impulses peak doesn't reside at a millisecond that corresponds to the left window width as expected
I've compared it to the convolution plugin that I use while mixing, and also to a free/demo (considered good) program...REW is an OK oversampler but not on a par with commercial applications.
Ok, perfectly clear; thanks!...That only affects graph generation.
I think I get what you are saying; I'll check that...That would suggest the ref time was not at the peak.
So, if I'm exporting four IRs, which have been measured using the same ref time (the one of the sweep generated by REW), and I want to maintain all the relative delays of the system measured (even if very small, for the usual "faithful to the hardware" purpose), does this means that, in this case, is better to avoid that "shift"?...That only moves the IR, it doesn't change it.
Hard to say, probably easiest to just try it.do you think that converting the sample rate while exporting the IR without applying the window (or applying a window that corresponds to the whole length of the IR), then importing again the converted IR, and only then exporting while applying the window, can give a better result compared to directly exporting/converting while applying the window?
Ok, I'll try that then...Hard to say, probably easiest to just try it.
Perfect, thanks. Which leads to my last question (finally)...If you want to preserve relative timing then avoid moving any individual IR.
Ok, thank you!... But...Use the offset t= 0 controls to move both C and D by the time required to align C with A.
You could look at the difference between the figures produced by Estimate IR delay for each of them, or you could look at the difference between their individual delay figures if they were both measured with the same timing reference.How do I know the exact time required to align C with A?
EQ filters are causal and minimum phase.are those EQ filters "immune" to this?
Ok, good: as I was thinking using them shouldn't generate an "acausal" response, just like when mixing and using a minimum phase EQ...EQ filters are causal and minimum phase.
If I'm not wrong the second method is more "precise", right? Anyway, I used the same sweep, which contained also a Time ref...You could look at the difference between the figures produced by Estimate IR delay for each of them, or you could look at the difference between their individual delay figures if they were both measured with the same timing reference.
Ok, you're clarifying that the "timing reference" (contained in the measurements) and the "reference time for windows" are actually two different things...The timing reference establishes the position for t=0.
The reference time for windows (which is used to position the windows)
Ok, I think I get it: that's for the fact that it can vary that it is not necessarily true that, to align different impulses, is enough to keep their own respective ref time (as they are "automatically calculated" by REW), while also making sure that they have the same left width, right?...The reference time for windows (which is used to position the windows) can vary, it is usually at the peak of the IR.
Yes, this is something I had already figured out...If you want to export windowed responses to preserve relative delays you need to make sure the windows start at the same time. That is done by making sure they all have the same left width and they all have the same window reference time.
Should give the same result.what's better, regarding the EQ filters, to "Export EQ filtered IR", or "Generate measurement from predicted" and then export that?
Thank you again!...Should give the same result.
REW always puts the ref time at the peak, but you may change it afterwards.what can make REW not put the window ref time at the impulse peak?
