REW FR after miniDsp EQ results
ciotime
Denon X3700H
Denon X3700H
Denon AVR 3313
Sony
B&W 602 S3
B&W 303
Paradigm PDR12 and PDR10
BenQ HT3550
Grandview Tab Tension
After getting 3 new SVS subs I had to redo my calibration. Spent a couple of days and hours doing REW with the miniDsp 2X4HD I was finally able to get the results which to me looks good. I was able to gets good results earlier but once I moved to take measurements to the Left and Right of the MLP it just was too different. Anyway I'm posting this in hopes of getting as much opinion as I can get and if there's some more I need to do to make it even better. Thanks.
SUB placement:
Sub 1-Left front wall 1/4th
Sub 2-Right side wall 1/4th
Sub 3-Rear middle wall
AVA Cinema
Not sure what I'm lookin at... ??? Need the legends.
Is this all three subs with the mains from the center of the primary listening position, which is where you will get the most significant response.
ciotime
Denon X3700H
Denon X3700H
Denon AVR 3313
Sony
B&W 602 S3
B&W 303
BenQ HT3550
The pictures above are the Spectrogram, RT60 and the Freq Response with all 3 subs ON and also with Audyssey ON. The 3 responses were taken at 3 different positions in a 3 seater sofa...the middle seat and the Left/Right seats next to the MLP.
ciotime
Denon X3700H
Denon X3700H
Denon AVR 3313
Sony
B&W 602 S3
B&W 303
BenQ HT3550
This is after applying EQ on the miniDsp 2X4 HD with 1/12th smoothing.
perceval
First, the scale of the spectrograph is huge... anything will look flat. Are you really hoping that the bass will not arrive 1 full second later? a 0 to 300 max would show what's happening in your room. 0 to 100 if you want to see reflections from stuff in your room.
And, a 15dB drop between the lowest lows and 250Hz? I guess you like when things are shaking in the house! ha ha!
It's ok. You like a lot of bass. A lot more than me. Every taste is different. But that is a lot. Just saying! ;)
It's normal to have different readings from the left and the right side. I doubt your room is perfectly symmetrical, so, a coffee table on one side, a sub closer to a wall on the other, all will introduce variations. The important thing is to play on the strengths and not try to boost the nulls. So, if there's a null frequency on one side that you just can't get rid of by moving the subs around a bit, but the other side is fine, boost the side that is fine a little to balance the null from the other side.
Don't try to boost the null (dip) as it will just introduce a lot of distortion.
ciotime
Denon X3700H
Denon X3700H
Denon AVR 3313
Sony
B&W 602 S3
B&W 303
BenQ HT3550
Thanks for the advice...it is a dedicated room but you are right the sofa etc introduce other factors. I've attached some pictures of the room as well as re-measured after doing some more EQ along with the curve editor app using Ratbuddyssey.
First graph-No smoothing/Sub only and mains only/with miniDsp Audyssey ON/MultEQ Filter Freq Range LIMIT to 450Hz on all speakers/SUB limit to 20Hz
Second graph-No smoothing/Sub only and mains only/with miniDsp Audyssey ON/MultEQ Filter Freq Range LIMIT to 450Hz on all speakers/SUB limit to 250Hz/added house curve using Ratbuddyssey
Third graph-No smoothing/Full range comparison of First and Second graph/added +6dB to sub trim level/BLUE is first graph Brown is from the second graph with no limit to the sub in MultEQ Filter Freq Range
Ton
Mytech Brooklyn Bridge
Krell KST 100
Duntech Crown Prince
REL S3 SHO
How does it sound?
