REW losing input device
JImmy Bobarino
RX-V3300
Xbox one
JBL 590
JBL 520c
JBL N24
JBL N24
SUB -1200
I have been having issues with REW losing the input signal when doing sweeps. If I reselect the mic it will work again, although some times it seems to lose calibration. I suspect it is an issue with my computer as it is newer. I was just curious if anybody else has had this issue and how they fixed it. I was hoping updating REW would do the trick, but no luck.
What mic are you using? If it's a UMIK-1 make sure the connector is pushed very firmly into the back of the mic.
JImmy Bobarino
RX-V3300
Xbox one
JBL 590
JBL 520c
JBL N24
JBL N24
SUB -1200
Messing with the cable it turned out to be the end going into the computer.
Thanks for the quick reply.
