REW V5.19 release
nbn44
Привет, Джон
Опять же, проблема с отсутствием рабочего поля экрана в установке параметров Thiele-Small - можно ли их показать справа?
Google translate to the rescue. I gather the problem is the dialog being cut off due to screen size? That screen shot is 1024x600, the REW help does say 1024x768 is the minimum supported screen size. I can get rid of the heading in the results area, it is redundant anyway. That means the parameters up to QTS are visible. I'll do that for the next beta, otherwise you'll have to write them out to file, I'm afraid.
Note that you can also try reducing the font size REW uses in the View preferences, that may help.
nbn44
Thanks, John
Unfortunately, changing the font size did not help ((
Maybe the results show in another window.
let us say
nbn44
Yes, it is, but not habitually small ((((
Let's wait for finalization and for the time being I will save in the file
FargateOne
Rotel RSX-1562
Bryston 3B3 for fronts mains
Cambridge CXU
B&W 804 D2
B&W HTM4D2
B&W 705
Samsung UN55ES8000
miniDSP 2x4 HD
HI John,
here are the screen captures when I tried to reinstall REW hope that helps
Don't see anything about file corruption? The installer seems convinced you don't have a 64-bit JRE, did you follow the link to download one?
FargateOne
Rotel RSX-1562
Cambridge CXU
B&W 804 D2
B&W HTM4D2
B&W 705
Samsung UN55ES8000
miniDSP 2x4 HD
Dear John,
thank for your reply. Following your commentary, I have uninstalled all older versions of java an installed the latest called "jre-8u191-windows-x64" du 16 octobre 2018. I will see what happens next time I will update REW and report.
FargateOne
Rotel RSX-1562
Cambridge CXU
B&W 804 D2
B&W HTM4D2
B&W 705
Samsung UN55ES8000
miniDSP 2x4 HD
I usualle use Firefox instead of Explorer. I was following the instruction of Java web site saying to dowmload the 32 bit and the 64 bit versions because Firefox did not seems to be 64 bit. Now I only have the 64 bits of Java and Rew is fine and Firefox too...I am an electronics-computer dinosaure...
Shareef Jalloq
Hey, first post since this all moved to AV NIRVANA. Just installed 5.19 on my Mac on 10.13.6 and I've noticed two bugs.
1. Every time I start REW I get a pop up telling me that 5.19 is out and that I can download an update.
2. I'm using a UMIK-1 with a cal file and I keep getting asked if I want to use it for measurement and it wants pointing at the cal file. Why isn't this being cached in some profile/config file?
Cheers.
Are you sure it is not telling you about 5.20 beta 1?
It is, though it won't be if you disconnect the mic before closing REW or if you don't either let REW select the mic as an input or select it in the REW soundcard preferences yourself.
FargateOne
Rotel RSX-1562
Cambridge CXU
B&W 804 D2
B&W HTM4D2
B&W 705
Samsung UN55ES8000
miniDSP 2x4 HD
Surprisingly I have the same message in my desk and laptop computors although I know that we are now in 5.20 version !
FargateOne
Rotel RSX-1562
Cambridge CXU
B&W 804 D2
B&W HTM4D2
B&W 705
Samsung UN55ES8000
miniDSP 2x4 HD
there it is and now I read the full message and it is ok sorry my bad...a dinosaure I am and sometimes I have to concentrate more...
OK, that's as expected - running 5.19 and being told about 5.20 beta 1.
Edit: the changes box could highlight that it is 5.20 beta 1 changes from 5.19, I'll do that in future.
