- Main Amp
- Additional Amp
- StormAudio PA 16 MK3
- Computer Audio
- Intel NUC w/ Roon ROCK
- Panasonic UB9000 4K UHD Player (for media discs)
- RTJ 410
- Center Channel Speaker
- MartinLogan Focus C-18
- Front Wide Speakers
- JTR Neosis 110HT
- Surround Speakers
- JTR Neosis 210RT
- Surround Back Speakers
- JTR Neosis 210RT
- Front Height Speakers
- JTR Neosis 110HT-SL
- Middle Height Speakers
- Rear Height Speakers
- JTR Captivators - 4000ULF-TL x2 + 2400 x6
- Other Speakers or Equipment
- VTI Amp Stands for the Monoblocks
- Video Display Device
- Sony 98X90L
- Remote Control
- AVA Cinema
- Streaming Equipment
- Kaleidescape | Lenova X1 - Intel NUC for Roon
- Streaming Subscriptions
- Satellite System
- Dish Joey 4K
- Other Equipment
- Zero Surge 8R15W-1 | Salamander Synergy Equipment Stand
Yep... I have the Velox and I have the Audioquest Pearl ... neither worked any better on the Roku to solve its issues. I have the Nvidia Shield, and the first unit I had it had some issues, but I think it was ultimately a bad cable.... and the second unit I have had absolutely zero issues. My handshakes are now much faster and everything works like it should. I don't like the interface as well as I do the Roku... but that is a minor thing, as that is only used to get to whatever app you want to get to... Netflix, Amazon, Hulu, etc. You could rearrange the apps on the Roku, but on the Shield they are all on one row and I haven't figured out any way to organize them any better. It may be right under my nose and I just haven't seen it yet. And if you use an IR learning remote, which I do (MX-890), then you have to get the Pro to get IR capable remote functions.Sonnie - did you try the Velox cables with the Roku? If they didn't work for you, I doubt they would for me. How's the Nvidia product working?
