Set up my son inlaw with a home theater built around some older components.
3dbinCanada
PSB Image 1B
Logitech Harmony 650
BlueSound Node2i
My son inlaw's system except for the display are components I gave him. The amp is a Yamaha RX-V1800 AVR rated conservatively at a 130 Watts/per channel when driving only two channels full bandwidth into 8 ohms. Its a 7 channel amp. I think its was produced in 2008. He has a Panasonic 720P plasma display, a Roku stream stick, and a Bluetooth to analog out converter connected to it. The main speakers are the orginal PSB Alpha, PSB Alpha center channel, and the surrounds are PSB Alpha Minis. There are two subs connected to it, a PSB Subsonic 5 which is a dual port 10" driver, and an Energy S8 single port 8" driver designs.
The initial set up looked like this.
Notice the sub locations. They are oriented with the driver towards the "pretend" listener position under the window. :)
The sub response in the initial placement
The full frequency response of the initial setup
I did not have my laptop and measurement MIC when we first set up the system.
3dbinCanada
PSB Image 1B
BlueSound Node2i
After moving both subs around and playing with phase, I determined that the best sub locations are as shown
Notice that both subs are now oriented with the drivers facing one another. The Energy sub was placed in the corner. Here is the in room sub responses.
At this point I ran Yamaha's YPAO room correction facility to integrate the remaining speakers with the sub into the room. YPAO put the virtual sub at 12.5 feet from the mic. I then ran a full frequency to see how it looked
There's a nasty notch happening between 65 and 150 Hz. I fixed this by playiing with the distance that YPAO had set and I found by trial and measurment that the best integrated response occured with the sub distance set to 8.5 feet as shown below
The room is an acoustic mess with bare walls, bare concrete floor, and duct work. The only thing sort of helping is that its an open ceiling. Its a bit too much for the earlier versions of YPAO to handle effectively. I set the EQ on YPAO to try and give a flat response. This version of YPAO was only effective from about 250 Hz and up.
Just to make it easier, I'll post full frequency response before and after today's work. There is no minidsp used here.
Before:
After
chrisby
Canada
Onkyo TX RZ740
Receiver
Hypex UCD180 for subs
N/A
N/A
N/A
N/A
DIY Mark Audio Alpair 10.3
DIY Mark Audio 10.3
N/A
DIY Mark Audio Alpair 6
DIY Mark Audio Pluvia 7
DIY a sealed 9” Eastech passive
LG 77 B2 OLED
Manufacturer’s for above devises
Cable provider’s set box Arris Xi6
Neftflix, Apple TV+, Prime, Disney+
N/A
Almost 6 weeks from your most recent post, so you may have already sorted things out, but in any case, few observations, thoughts.
What are room dimensions/ shape, and as it’s not shown in photos, the intended number of seats, main listening position, and type of seating?
It looks to be one of those long skinny basement areas with irregular height to partially unfinished ceiling.
For what it’s worth, it’s been my experience that firing down the room’s long(er) dimension yields better results - even if an L-shape - and it generally allows for MLP away from back wall. I usually try for that at about 60% of the long dimension. If that’s not possible, endeavour for a combination of absorption and diffusion on the back wall, but realize that the surround effect may not be as immersive.
From the photos it seems the rear surrounds are mounted wider & higher than the mains. If possible, play with that a bit - while the Yammie’s DSP would allow for adjusting delays for varied distances, I always aspire to symmetry of place in regards to MLP and room boundaries.
I also try to avoid large reflective surfaces such as the glass coffee table between the front row and MLP.
And yes, some treatment would most likely help quite a bit - starting with the first reflection points on side walls, what appears to be exposed HVAC ducting - 1/2” felt or even the back side of vinyl faced fibreglass suspended ceiling tiles wrapped in old pillow cases - and more of the floor than the small rug.
How do the RTA, waterfall and spectrographs look? While the final couple of FR curves show some definite improvement, they don’t tell the whole story.
While it isn’t festooned with the latest generation of bells and whistles- sometimes a blessing in disguise - the RV1800 is still a pretty potent piece.
Anyways, these are always fun shared learning experiences, and a great excuse to share a 6-pack or whatever your favorite beverage might be.
Oh yeah, while it doesn’t possess all the latest bells and whistles - sometimes a blessing in disguise - the RV1800 is still a pretty nice piece.
