Newfiestang50
- Jan 17, 2024
- 29
- Yamaha RXV-2600
- Main Amp
- Emotiva XPA-2
- Additional Amp
- NAD 272
- Streaming Equipment
- Sonos Amp
- PSB Stratus Gold i
- Dual SVS SB3000
I have not used RTA and I am not familiar with it at all.For Pink noise record ”Pink Periodic”
Record left only, right only and both so you’ll have what you need.
Have you used REW’s RTA?
Are you familiar with Moving Mic Method for recording spatial average with Pink noise?
MMM mouving measurements method, which one is best with REW?
Hi, I saw this video: And I was surprised how fast they seem to move the mic. I am only an amateur here, but I followed the following method instead: https://mehlau.net/audio/room-correction-peq/index.html Measure speaker response Set RTA > Averages > forever Hold the mic at the main...www.avnirvana.com
Record measurement sweeps with a timing reference (it’s an option you can check)
Left and right channels. Keep timing reference the same, can be either left or right.
Timing reference will be required for phase alignment of subs to mains through crossover region.
Here’s a thread for what this is about if you need it. Member @jtalden is the expert here…
REW Alignment tool - Guides or Manual?
Hi All I have just taken a batch of measurements for LCR and sub using REW (using an acoustic timing ref) and am trying to use the new alignment tool to determine the best delays to add to my processor. But I can’t find anything that explains how to use the tool - no manual, no videos or...www.avnirvana.com
I have done some ready on the moving mic method but again havent used it.
I dont see the timing ref check box on REW as you can see in the screenshots in last post and i am using version V5.30.4. I do see it when the play tab is selected under sweeps but i will be playing sweeps from my tablet so not sure how that will work.
