Speaker calibration using a networked sound device
DSt
daniel.stolzberg@gmail.com
Hello,
I would like to use REW to calibrate a speaker that is driven by a networked device (see bela.io). I can send and play a wav file over this device. I can record the mic output directly into a USB soundcard on my computer (mac).
I am wondering if there exists a procedure whereby I can play a wav file - ex: a sine swept stimulus - to create a compensated transfer function of the networked sound card/speaker.
Any ideas? Please let me know if anything is unclear.
Thanks,
Dan
Planetnine
Is this the only way that a sweep can be played over networked audio on a PC while measuring on a Umik-1 please John?
I have a USB Umik-1 to measure the audio, and the networked audio device is accessed via ASIO. Unfortunately I don't think I can configure ASIO for the output and the Umik-1 for the input in Preferences/Soundcard.
Could this be made possible please, or will I have to save the sweep as a wav and play via another media application while measuring with the Umik-1?
Many thanks.
ASIO requires inputs and outputs to be from the same device. You may be able to use ASIO4All, which creates a synthetic ASIO device using WDM drivers for multiple devices, to do what you want using ASIO drivers.
