SVS 20-39 PC+
hydrovac
Hi all,
I would like to know the rail voltage of 20-39 PC+ power amp... the SMPS got busted, can any one provide me with the details please.
Mike Schramm
Bright Side Crew
Minooka, Illinois
Onkyo TX-RZ840
Emotiva BasX A7
Panasonic DP-UB820
SVS Ultra Bookshelves
SVS Ultra Center
SVS Prime Satellites
SVS PB-2000 Pro (x2)
miniDSP 2x4 HD
Sony XR-77A80J
Logitech Harmony One
Apple 4K
Netflix, Hulu, Apple Music, Amazon Prime
I’m sorry, this is well out of my wheelhouse. Have you tried contacting SVS? Their customer service is top notch. They have Sunday hours as well (12-4 pm ET).
hydrovac
I already did... they are not able to help. Hopeless customer support in understanding a basic query.
Mike Schramm
Bright Side Crew
Minooka, Illinois
Onkyo TX-RZ840
Emotiva BasX A7
Panasonic DP-UB820
SVS Ultra Center
miniDSP 2x4 HD
Sony XR-77A80J
Apple 4K
Ugh. Well that stinks. Hopefully someone in the forum is more knowledgeable than I am. Sorry!
May be hard to find. I have one, but it's broken. Actually, I think I finally trashed it after several years of storage.
kickerzx
Yamaha RX-V3800
Emotiva XPA-2 gen 1 (main channels)
Nad 218 (sub and centerchannel)
Oppo BDP 103
SVS MTS 01
SVS MCS 01
SVS MBS 01
SVS PC pluss 20-39. Blown amp. Using NAD 218 on it
Antimode 8033c
Sony W905A 55"
Harmony Ultimate
2. room. MiniDSP 2x4HD, NAD 916, JAMO 606, Sonos
Sorry, i cant help either, but i were in the same boat a few years back.
The amps are made by Indigo in Canada. When mine broke i tried to figure out what was wrong with it. Could net get my hands on a circuit diagram so it was all done by trial end error. An equal amount of both actually so it ended in an error.
I even bought several broken amps to try and figure them out (all had the same fault in the powersupply). I actually soldered and desoldered parts on them so many times that the circuit traces went fubar eventually and i no longer bothered with it. Im not a very good amp repair man though. I just dabble with stuff like that from time to time in my garage
Ended up buying used a 3kw PA rack amp for it and have used that setup ever sinse
All that said i think i read resently somewhere that the rail voltages are variable on theese
Wayne A. Pflughaupt
Corpus Christi, TX
Canton Karat 920
Canton Karat 920
Canton Plus D
Hsu ULS-15 MKII
Stock Yamaha Remote
Roku Express
What @kickerz said – outboard amplifier. It shouldn’t be hard to convert the 20-39 to a passive sub, enabling you to use the amplifier of your choice. I’ve done it to two subs. It’ll be a piece of cake for someone like you who’s capable of doing board-level work.
