Can You Hear A Difference Between Amps?
Can you hear a difference between amps?
  • Yes.
    Votes: 10 55.6%
  • No.
    Votes: 8 44.4%
  • Total voters
    18
Jack
Active Member
Southern Indiana
Emotiva XPA5
Darid I30
Hafler 220
Oppo
Klipsch KLF10
Klipsch C7
Various
HSU VTF-3 MK5 HP
Panasonic Viera Plasma, 65"
Lots
In reviewing all of the great posts above, it would seem we have com,e up with dozens of ideas why not all amplifiers sound the same. Maybe however, we have added dozens of qualifiers that could indeed disqualify all amplifiers from sounding the same.
I do agree that many amps may sound "Similar" , however, I can say with some expertise, that one might not easily call out differences between most tube amps and solid state amps in way of a "Sound". Nope, the "Warm" sound that used to identify tube amps from their solid state brethren have all but disappeared...unless of course we choose tube rolling to make it so.
Carver did change the sound of his little can amp over the period of a long weekend so that its sound was close to that of a conrad johnson tube amp.
AudiocRaver
Senior Reviewer
North Carolina, USA
Onkyo TX-SR705 Receiver
Phantom Center
NSM Audio Model 5 2-Way (x2)
Perhaps the biggest lesson here is that it is far from being an easy question to answer.
Here is an example that stands out in my mind:
While reviewing the Perfect Storm, by Vapor audio, at the Vapor Audio facility a couple of years back, I listened with 3 different amps driving the speakers. A "chip amp", a proprietary/preliminary design, performed well. Switching to a pair of tube amps, the bass was definitely changed (I'd have to review my notes to recall if it went up or down relative to the rest of the range, but I am quite sure the bass was stronger - that is consistent with a later tube amp experience to follow). Totally unexpected by me, yet the two other listeners present agreed when I commented about it. The third amps, a pair of solid state class A monoblocks, sounded like the lower-powered chip amp but had huge power reserves (as expected) .
When we first heard the same pair of speakers at AXPONA a few months later, they were driven by a pair of tube amps. This time it was the treble end that seemed subdued - I remember that clearly (same as the bass being stronger, right?). That night, one of the tube amps fried and they borrowed a solid state amp/pair (not sure if stereo or two monoblocks) to drive them with. Next day, I could tell when I entered the room before sitting down that the high end was back as I had heard it before.
All of these differences were unexpected and distinctive, although not "night and day" differences. Since then I have listened and heard fine differences on a number of occasions that could only be attributed to amp differences. And I have been pretty firmly in the camp of "you can NOT hear the differences" for a long time before these experiences.
HOWEVER, in every case, there was an explanation. Damping factor, channel separation specs, monoblocks vs. stereo amp (channel separation again), internal DAC design differences (reconstruction filter difference - OK not really part of the AMP sound question, but the kind of difference some might hear and blame on the amp design).
Lesson: listen carefully and don't jump to conclusions. If there is a difference, look for an explanation. If you can hear a difference and explain it, even with both amps operating "in range," then accept it.
As said by others, none of these differences were "hit you over the head" obvious. I guess another lesson is that when you start to listen more carefully for certain differences, you are likely to start hearing them because your attention is more focused on them and your psychoacoustical brain is being trained and becoming more sensitive to them. If you don't want to be able to hear them, don't start listening for them.
AND, always look for checks and balances to keep the imagination in check. AB tests, other listeners, etc. Someone like Dennis or Leonard or Sonnie or Todd to keep you honest is always a good bet.
GFOviedo
I can only hear how loud a pro amp runs compare to my LPA-1 amp. I used to have a Crown and QSC amps and their fans were loud. Otherwise, I didn't really hear a sound difference at all. My current set up isn't super high quality either.
Sonnie Parker
Music Server
ROON Nucleus One
Turntable/Cartridge
Music Hall Stealth Turntable
Ortofon 2M Blue Cartridge
Kaleidescape
Lenovo X1 Carbon
FireCube 3
Zero Surge 8R15W-1
Zero Surge 2R20W
Wharfedale Super Linton
AVA Cinema
Cables
AudioQuest - Various
THX PixelGen HDMI
Pangea Power Cables
Custom Cables
Network/Internet
C-Spire 1Gig Fiber
Omada OC300 Controller
Omada ER8411 10G Router
Headphones/IEMs
HIFIMAN HE1000se
Unique Melody Mest MKII
Headphone DAC/Amp
Eversolo DMP-A6
RME ADI-2 DAC FS
HIFIMAN Goldenwave Serenade
Whole House System
HEOS System
Home-150 Speaker x6
Samsung S9 Tablet w/ HEOS
Office/Study System
Office System
Dell Precision Computer
Roon Networked
AV Test Room System
NAD M33 Streaming DAC Amp
MartinLogan Motion XT F200
JTR Captivator RS1
miniDSP EARS
Zero Surge 8R15W-1
Zero Surge 2R20W
Dell Optiplex
Roon Networked
Additional Room System
Sunroom System
Zu Audio DW-6 Speakers
Roon Networked
Dish Joey
JVC 37" TV
Cabin System
Onkyo TX-SR805 Receiver
Infinity Primus P163 Speakers
Shield TV Pro
Sony 55" TV
Vinyl Room
Technics SL-1210GR2 Turntable
KLH Model Three Speakers
Zero Surge 8R15W-1
Barn Jam
Soundfield Custom Speakers
We've changed out a quite a few fans in the Behringer EP amps over the years to install quieter fans.
