If you've previously downloaded sweeps, you should download new ones. Here are new 1M sweeps:
[REMOVED, CANNOT POST LINKS YET]
and here are new 256k sweeps:
With the previous versions, I foolishly assumed the auto-generated Dolby dialog normalization metadata value would be the same for all files, since the content was the same, just on different channels. Bad assumption; it turns out dialnorm varied across the files, so absolute level for the sweeps was not consistent. I figured out a way to make them all the same, hence the new versions.
