SimpleDude
- Aug 29, 2023
- 5
Thanks, did you have any recommendations about using the 0° or the 90° file for the UMIK1 for Atmos channnel measurements?
If the height speakers are at the standard 45° angle to the listening position, then I don't know which is better, sorry.Thanks, did you have any recommendations about using the 0° or the 90° file for the UMIK1 for Atmos channnel measurements?
Correct me if I am wrong but will they not need to have .mlp extension which is not playable with public media players?At one point I toyed with the idea of buying a 1-year license to the Dolby Media Encoder, because TrueHD Atmos sweeps would be nice to have, but it seems to only be available to companies, not individuals..
VLC will play .mlp files, and various apps will play TrueHD Atmos in an mp4 or mkv container.Correct me if I am wrong but will they not need to have .mlp extension which is not playable with public media players?
What do you think of this trial of mine?VLC will play .mlp files, and various apps will play TrueHD Atmos in an mp4 or mkv container.
How did you produce it?What do you think of this trial of mine?
I'll leave you in suspense for a bitHow did you produce it?
I only have a x.x.4 system, so I've never been able to test the TML/R signals properly. But, I've just recently figured out another unfortunate fact about how the AWS service encoded the files. There's a flag in the DD+ Atmos metadata that can be used to specify whether bed channels are intended to be "distributed to multiple appropriate loudspeakers". That flag is unfortunately set in all of the sweeps, so it's quite possible that's causing the middle sweeps to be expanded.When playing back the TML and TMR signals, I also the corresponding front and rear height speakers also seem to be playing. I also see this reflected in the peak level view for each channel on my Trinnov processor. The other height channels work fine. Have you seen this?
Unfortunately, the AWS service used to encode them doesn't allow dialnorm to be explicitly configured, the service sets it automatically, and it ends up setting dialnorm so the volume is very low.Also, what level are these tracks mixed at?
VLC will play them, but you need to enable HDMI/SPDIF audio passthrough in the audio settings. The Movies & TV also works. On Windows 10, Windows Media Player (not the same as Media Player) works; on Windows 11, you need to use Windows Media Player Legacy instead.What app are folks using to play back these files?
They also play on some Blu Ray players, such as those made by Oppo, or basically anything that runs Kodi.I only have a x.x.4 system, so I've never been able to test the TML/R signals properly. But, I've just recently figured out another unfortunate fact about how the AWS service encoded the files. There's a flag in the DD+ Atmos metadata that can be used to specify whether bed channels are intended to be "distributed to multiple appropriate loudspeakers". That flag is unfortunately set in all of the sweeps, so it's quite possible that's causing the middle sweeps to be expanded.
Although @serko70 hasn't announced it here, you're now better off using his lossless TrueHD Atmos 9.1.6 sweeps (download link in the YT description):
Those files can be played with VLC.
Hmm, I don't know if @serko70 tested on an x.x.6 system.I've also tried the same preset / layout as with serko70's files, with the same effect. I wouldn't be surprised if one can assemble a speaker layout that uses only one speaker for each sweep, but my attempts so far weren't successful.
I somehow missed OCA's Youtube post. Thx for the link. I downloaded those files and the chapter grouping makes it quite easy to hop around different speakers. The sweeps on his files seem to be good except for the front wides; for those speakers the side surrounds are also enabled.I only have a x.x.4 system, so I've never been able to test the TML/R signals properly. But, I've just recently figured out another unfortunate fact about how the AWS service encoded the files. There's a flag in the DD+ Atmos metadata that can be used to specify whether bed channels are intended to be "distributed to multiple appropriate loudspeakers". That flag is unfortunately set in all of the sweeps, so it's quite possible that's causing the middle sweeps to be expanded.
Great stuff. Thanks for doing this and sharing the files!Before I go too far down the rabbit hole, here are four files that others can test, to see if I'm on a useful track. These are audio-only mp4 measurement sweep files for height speakers (x.x.4), with timing ref in the Center channel. They are derived from an REW-generated sweep file with parameters 1M length, 20 Hz to 20 kHz, -12 dBFS, 48 kHz, 32-bit Float, so you should use those parameters to generate your local sweep file to load into REW (resulting file name is 1MMeasSweep_20_to_20000_-12_dBFS_48k_Float_L_refR.wav).
Let me know if they work for you, or if you don't like the parameters. The overall volume level is lower than what I expected, so that's something still to investigate.
Edit: these links no longer work, see later post for full download.
That’s a great idea.@serko70 @thothsong Do you have any way to make pink noise at-30 dBFS for the atmos channels? I'm currently running a 7.1.4, and level matching at 70db @ 0 MV with the -30dbfs pink noise via REW.
I had created lossless M-Noise sweeps a while back (mkv format, 46 seconds each). They are all at equal volume to each other with dialnorm settings off but there's no easy way to measure their dbFS levels accurately. Still, it will help with level matching probably even better than pink noise as they have higher crest factor:That’s a great idea.
Fantastic! Thanks for sharing!Dolby provides DD+ Atmos full range pink noise files:
I have in the past produced DD+ Atmos 7.1.4 SpeakerCal/SubCal pink noise files:
The files are named for a Samsung soundbar, but the mapping should be clear.
I don't know for the Dolby files. For my files, the source files were generated with REW using -12 dBFS, but there's no way to control the Dolby dialnorm for the AWS output, and the dialnorm used is 16.@thothsong Any idea what dBFS these are recorded in?
