How many subwoofers are you using in your main system or home theater?
doug s.
music listening only, here. not even a tv, let alone h/t. listening room is 26x38x8.5. two vmps larger subs 6' from the front wall, 12' from the listening area. a pair of aci sub-1's sit directly behind them. 20' behind the listening area against the rear wall are a 2nd pair of vmps larger subs. as the room opens to two other spaces, it barely pressurizes the listening area. the vmps subs are really musical; they will do 115db at 20hz w/max 2.5% distortion. powering the front subs and the aci's are one channel of a pair of crown xls2000's, crossed over at 60hz. the other channel of each crown powers 15" fostex pro audio drivers in heavily strengthened klipsch lascala cabinets, from 60-175hz.. the vmps' in the back of the room are driven by a home-brew hypex amp which puts out 180wpc into the vmps' 4 ohm load. the crowns see a 2 ohm load with the aci and the vmps connected in parallel, which means they can put out >1kw. but they don't need nearly that much power as they're quite efficient.
i have tang band w8-1772's in oris 150 horns, run from 175hz-7khs, w/beryllium ribbons tweeters salvaged from a pair of pioneer s-1010's >7khz. this completes the actively quad-amped system, which measures quite flat in my room. i'm looking forward to the arrival of a pair of bms 4590 coax compression drivers and adapters designed by oris to hook them up to the 150's. according to oris' owner/designer, it's a killer improvement, superior to even the spendy fullrange drivers from aer, lowther, voxativ, etc.
doug s.
HSamwel
Emotiva RMC-1
Emotiva XPA-11 Gen 3
Pioneer UDP-LX800
SVS Ultra Tower
SVS Ultra Center
SVS Prime Satellite
SVS Prime Satellite
SVS Prime Elevation
SVS Prime Elevation
XTZ 12.17 Edge
Tell as much or as little as you'd like.
How many subs do you use in your main listening room or home theater?
What are the brands?
How are you equalizing your subs?
Do you have plans to add more?
I'm currently satisfied with my setup of two JTR 4000ULF-TL Captivators + six 2400 Captivators. I'm using the two 4000 units with dual 18s as my main subwoofers, and the other six are support subs using Dirac Live ART.
22,400 watts powering ten 18-inch subs in a 19.5ft x 23.5ft x 8.5ft fully sealed room. :hsd:
I currently have two 12” XTZ SUB 12.17 Edge.
I’m using Dirac Live for calibration.
Have been thinking about investing in a couple more subs. Not necessarily two of the same model.
Maybe one bigger to help with the tactile feeling. I could place it directly behind my seating. But this would
be in the middle of the room, about two thirds distace from the front wall. Don’t know if that would improve
or make bass worse?!
My room is quite small, atleast the width, so I don’t have infinite space to have many or large subs.
It measures 6.9 x 3.6 x 2.4 meters (LxWxH) which is about 22.6 x 11.8 x 7.8 feet.
I have one row of seating for three persons.
It’s a livingroom that I have setup with 9.2.4.
RickT5
Marantz SR6014
Panasonic DMP-BDT220
AppleTV 4K, Dual APC Back-UPS Pro 1500S
Emotiva ERM-1
Emotiva ERM-1
Emotiva ERD-1
Radio Shack Minimus-7
Cambridge Soundworks Basscube 8
Vizio M558-G1 UHDTV
Harmony Hub
I have two Emotiva Airmotiv XS10 Subwoofers connected to a Marantz SR6014 AVR. I use the Marantz Audysset MultiEQ to equalize the subs along with the rest of my 5.2 setup. I do not plan to add more subs. The L-C-R speakers are old Emotiva ERM-1's that still sound great after so many years, and my side surrounds are a pair of Emotiva ERD-1's.
GarryH
Denon 4400H
2x Velodyne 5000 -15" / 2x Klipsch sub12 - 12"
I have two old Velodyne 5000's and two old Klipsch 12's (down firing).
All are in corners of a 24' square(ish) room with 9 foot ceilings.
I bought a MiniDSP 2x4HD but haven't set it up yet. - Looks like lots of work.
harishkatyal
Marantz SR8015
Marantz MM8077
Earlier in my large living room setup (22 feet x 14feet) with open kitchen I had 4 sub woofers ( 2 SVS SB4000 and 2 Golden Ear ) all equalised through 2x4 mini DSP HD. It was working very good. Now I have shifted and shall be having dedicated home theatre room 13x11 and shall install only 2 subs initially SB 4000 2 nos. I think it should be more than sufficient because I am getting the room properly Acoustically treated. The room is of brick wall. So I am installing 1 layer of MLv 3mm , then Isolation block 25 mm, polywool 25 mm, 12 mm perforated ply, then 12 mm foam with fabric. Will update once this setup is complete
Atmos7
Yamaha RX-A8A
Yamaha
Klipsch RP8000F
Klipsch RP504C
Micca M-8C
None
Micca M-8C
Micca M-8C
Klipsch R-12SW
I have two Klipsch SW12 driven by Yamaha A8A, equilised by Yamaha YPAO. I have mid-size living room. It is more than adequate. Gain is set at about 40%. More than adequate for the room. At higher gain, the windows in the house rattle
Sal1950
Marantz AV7703 PrePro
(2) Adcom GFA545 II
(1) Adcom GFA5400
(2) Adcom GFA535 II
Emotiva DC-1
DIY Tower, PCLinuxOS
Samsung UBD-K8500
Desktop Computer
Amazon HD
JBL HDI-3600
JBL HDI-4500
JBL HDI-3600
Klispch HT500
Klispch HT500
(2) SVS SB2000 (2) HSU STF-2
Emotiva DC-1 Headphone Amp
75"
Sony XBR75 X940D
Stock
LCSeminole
Florida Panhandle
Emotiva RMC-1(DL v3.6.7)(7.4.4)
Emotiva XPA-7 Gen3
Emotiva PA-1 (x4)
Oppo UDP-203 / Panasonic DP-UB820
AppleTV4K (2022)
Hulu Live TV / Disney+ / AppleTV+ / PrimeVideo
Arendal Sound 1723 Tower THX
Arendal Sound 1723 Center THX
Arendal Sound 1723 Bookshelf S THX
Arendal Sound 1723 Height S
PSA TV1813M(x2) / SVS PB12-Plus(x2)
Furman PL-PRO DMC 20A / Monster Power HTS-5000
Sony XR-77A80J (ISF Calibrated by ChadB)
Harmony Hub & Elite/665
DSPeaker Anti-Mode 2.0 Dual Core
Two PSA 1813M subwoofers and an Anti-Mode 2.0 Dual Core for the EQ. As for plans to add more, well I don’t have any plans right now, but since when do we ever need plans to improve/upgrade the home theater?……and I’m not married so no WAF!!!
JImL
I am using (2)Hsu VTF-15H mkll with one port open. I am using a Bryston 10B EQ with a DSpeaker 2.0 anti-mode room correction.
Doubtful If I will ever replace them but who knows?
Nemesis.ie
Trinnov Altitude 32
Purifier 1ET400
Schiit modius
Xbox series X
ATV 4k, Fire TV max, Xbox SX, CC ultra
NF, D+, ATV, P+, Spotify
Emotiva
Emotiva C3 (vertical)
Emotivs
Emotiva
Emotiva
Emotiva
Rythmik (4), Fluid Audio (2), ESI (1), Monolith (1
Screen Excellence AT
JVC NZ8
Harmony Elite
11.
4 x Rythmik 15", 1 x REL 15", 2 x REL 12", 2 x SVS 12" and 2 x 18" Subzeros.
Using Trinnov Waveforming.
Room is 5.2 x 3.2 x 2.45 m.
Tgunzz
Pioneer SC-09 Receiver
Oppo 203 4k bluray player
Roku
Netflix, Prime, Disney plus, HBO Max
Boston VR 975 Towers
Boston VR -12 Center
Boston VR -MX surrounds
Boston VRM -EX surrounds
Boston VR -2000 12” THX sub x 2
XYZ 100” 16 x 9 acoustically transparent screen
Panasonic ZT 65” plasma, Epson 5050ub projector
MX 3000 touchscreen remote
Panamax 5400 power conditioner
Still rockin my Boston Vr -2000 subs x 2. Almost pulled the trigger today on 2 RSL speed woofers 12” when I caught wind that JTR will be releasing a 12” sub. Now, I’m holding out a tad bit longer to see what Jeff delivers😁
Larsz77
I am running 4 x XTZ 10.17 edge in sealed mode. 3 up front in a LCR configuration, and one to the side to fill a response dip and shake our L-shaped couch. Using a Marantz Cinema 40 with Dirac Bass Control in a 5 4.6 setup. Don't have room for bigger subs, and the 4 identical 700w RMS pack a punch.
The sealed mode works better than ported. Did a lot of experiments and measured with REW. I Also never liked ported subwoofers.even with low RT60.
Sonnie Parker
Music Server
ROON Nucleus One
Turntable/Cartridge
Music Hall Stealth Turntable
Ortofon 2M Blue Cartridge
Kaleidescape
Lenovo X1 Carbon
FireCube 3
Zero Surge 8R15W-1
Zero Surge 2R20W
Wharfedale Super Linton
AVA Cinema
Cables
AudioQuest - Various
THX PixelGen HDMI
Pangea Power Cables
Custom Cables
Network/Internet
C-Spire 1Gig Fiber
Omada OC300 Controller
Omada ER8411 10G Router
Headphones/IEMs
HIFIMAN HE1000se
Unique Melody Mest MKII
Headphone DAC/Amp
Eversolo DMP-A6
RME ADI-2 DAC FS
HIFIMAN Goldenwave Serenade
Whole House System
HEOS System
Home-150 Speaker x6
Samsung S9 Tablet w/ HEOS
Office/Study System
Office System
Dell Precision Computer
Roon Networked
AV Test Room System
NAD M33 Streaming DAC Amp
MartinLogan Motion XT F200
JTR Captivator RS1
miniDSP EARS
Zero Surge 8R15W-1
Zero Surge 2R20W
Dell Optiplex
Roon Networked
Additional Room System
Sunroom System
Zu Audio DW-6 Speakers
Roon Networked
Dish Joey
JVC 37" TV
Cabin System
Onkyo TX-SR805 Receiver
Infinity Primus P163 Speakers
Shield TV Pro
Sony 55" TV
Vinyl Room
Technics SL-1210GR2 Turntable
KLH Model Three Speakers
Zero Surge 8R15W-1
Barn Jam
Soundfield Custom Speakers
11.
How are you liking the Waveforming?
HSamwel
Emotiva RMC-1
Pioneer UDP-LX800
SVS Ultra Tower
SVS Ultra Center
SVS Prime Satellite
SVS Prime Satellite
SVS Prime Elevation
SVS Prime Elevation
XTZ 12.17 Edge
11.
Using a Trinnov and 11 subs in a 5.2 by 3.2 meter space? Wow!!
The bass must be massive! Potentially earbursting if run at reference.. 😎
Is this correct?
May I ask how the rest of your system is set up?
  • Like
Reactions: VJM
basscleaner
USHER SD-500
Hi! My answer - I try to avoid of a sub use at all. To be honest, it's not simple task for Home Theater, but stereo, especially if your speaker's pair has LF range from 25-30 Hz. Due to dependence between Acoustical Room Dimensions and LF Power Point for equilateral triangle: sources-the test point, one may to do without any sub. Sometimes it works, but when not, - you have to use one, better two subs, placing them close to front speakers. I understand, that by means of multity of subs you can obtain smooth FR for LF range. But this way, to my opinion, is too expensive and not convenient for small rooms.
motorhead
Had up to 3 running in my living room cinema. All 12" DIY in closed boxes. they had been measured and tamed by Dirac on a MiniDSP DRC-88A plus bass management.
I have one more box ready plus 4 more chassis that are waiting for their chance.
Ruato
2 subs, both are SVS PB-1000. For equalizing I utilize Multi-Sub Optimizer (MSO) and Audyssey MultEQ XT32. No plans to add more. I live in a flat, so trying not to get all my neighbors angry.. :)
apcreek
I have 2 JTR RS1's in my dedicated cinema.
I use a Trinnov Altitude 16 to EQ my subs and plan on adding another 2 RS1's or maybe something a little cheaper for waveforming at some point in the next few years or so.
F.Calabrese
I am a speaker designer from 1978. Nowadays I use a couple of (horn) subwoofers, one against the front wall, the other on the back wall, opportunely phased and delayed to cancel the first room resonances.
The results are visible in the two graphs below: the first shows responde including direct arrival, while the second shows what happens after half a second of decay. Note that the only resonance remaining is below subwoofer passband.
esidue resonance is below subwoofer passband.
Gerry Iaria
Portugal
Marantz Cinema 50
Sony X800
Apple
Arendal 1961 monitors
Arendal 1961 centre monitor
Altec c1
Totem Acoustic Dream catcher
Arendal Sub1- Ken Kreisel 800
Samsung S95C 77inch
yes, L.O.L
lol... well... six of them are support subs used in the DLART processing, although I see them move more than my main subs at times. That's probably because the main subs have two 18s each.
It really makes the sub-bass effortless in my room.
Fantastic, if you can do that, why not :T
thexder
My room is currently under construction after moving into a new house.
For now, the equipment setup remains unchanged:
  • 4 Velodyne DD-15 subwoofers
  • Auto EQ via Audyssey for movies
  • Manual timing adjustments for stereo (with a lot of help from this community, especially @jtalden)
jjsilverstone
I have 11.
2 x Yamaha YST-160 (2x8” pr sub) on L and R. 5 x AudioPro B2-50 (2x6.5” pr sub) and 4 x Eltax Atomic 15.2R (1x15” pr sub).
In addition to that, 2 pcs of Buttkicker Concert and 1 pc of Buttkicker LFE. The 2 Concerts are run by the Buttkicker Amp and the Buttkicker LFE on another Buttkicker Amp.
All controlled from a Behringer DCX2496.
michaelspiellman
Wow, I can only imagine how good some of these setups must sound. My setup is pretty modest. The 7.2.2 system is in a rather large living room (26 x 16) and the two subs I'm running are SVS SB 3000's. They are located in opposite corners of the room. I used the room correction software on the Marantz SR 7015 to setup with the system. The system sounds pretty nice, although I strongly suspect all the systems listed in thread sound much better!!
