markus
- May 27, 2017
- 22
I am sorry. what is DL?
DL = Dirac Live
DL = Dirac Live
I don't know what it realy does, but afaik the target is aplied to a broad-window meassurement.
Here's the .mdat for those interested.
if the system is direct sound dominant, it is obvious that a full correction will make it more balanced.
now a reverbant system can look messed up in the LP meassurement, while in reality having a fully balanced direct sound. in this situation you would make things worse with the full correction
Yes.For more conclusive results the anechoic speaker response would need to be measured with and without Dirac Live.
FDW can be used to filter out the reverbant sound
There is nothing "highly" misleading about the thread title. Unfortunately we don't break down all the details in the thread title... but the thread has everything to do with EQ'ing full range. We did not include the name of product A, B, C, and D because it would have made the thread title too long. It all makes very good sense if you read the opening thread.That's not the only way to do this. Anyway, the thread title is highly misleading as "EQ’ing Full Range" with product A can be very different from "EQ’ing Full Range" with product B. Depends what kind of processing is actually applied. Quite a good overview can be found at https://www.mdpi.com/2076-3417/8/1/16/pdf
It not only comes down to the speaker, but it also depends on the room as well, which is mentioned in the opening thread.![]()
You are making some very glorious assumptions yourself Markus... and I really don't have time to waste defending what we did. If you are going to do nothing but have the kind of attitude that cast doubt on everything we do, it might be better you move on back to AVS where you can be a star. If you have something positive and constructive to add, please do... otherwise move on. Your condescending attitude is getting rather tiring.Huh? You've used DL for all tests, no? Hope you don't assume that any EQ approach would be the same and the only difference is "full range" vs. "limited"? That would be a major misconception.
There are a few well respected individuals out there that tell us not to EQ above 500Hz, that we may be doing more harm than good when we do.
I am surprised how many seem to prefer the "Harman" type bass boost of something like +10dB (or even more!) in the low end compared with 1kHz. Never liked that except for action movies. But I suppose those things also depends on the time domain behaviour
Yes so I bet your decay and other time domain graphs would also look pretty good in that case... no disrespect to anyone as I also like that lovely deep bass hitting me hard, but I think too many hifi-nerds who love bass have not yet heard the impact of properly time aligned and punchy bass,so they go for more volume instead. resulting in +10dB on the subs instead of getting the timing right.... IMHO...my bass is flat. and I use loudness compensation calibrated to -14LUFS music. one of Spotify's updates broke the normalization for me, so suddenly it got stuck at -11LUFS (loud setting). I din't realized this, but I noticed the bass starting no annoy me. the 3LUFS louder music resulted in 1.5dB-ish bass boost (because of the added -3dB compensation). so a simple 1.5 boost messed up the balance for me
It actually sounds balanced to my ears. The key is that your sub bass slopes down into the upper bass by ~120-150 Hz at most. The standard Harman curve continues to boost higher than that and in my experience does not sound as clean.I know it is all subjective and based on personal preferences but I am surprised how many seem to prefer the "Harman" type bass boost of something like +10dB (or even more!) in the low end compared with 1kHz. Never liked that except for action movies. But I suppose those things also depends on the time domain behaviour, which is not much discussed here.
By time domain behavoir I simply mean all the bass from the very low to the very high hitting your chest at about the same time, so that you physically can feel the kick, as opposed to just massive bass rumbling around in your room for too long, and starting at different times. And then there is the decay. The bass has to stop quickly too, to make this experience complete and that depends on the room properties (dimensions and absorbtion). I do not have the perfect system myself, by far, but as I said, I think too many people are crancking up their subs instead of getting them to kick at the right time and phase with their mains. Sooo much can be achieved there, with simple means (just correct delay/phase). And then some room correction afterwards... And preferably some really good bass traps to get the decay times down to reasonable levels (at least 20dB down within 100ms or so is in my experience really really good below 80Hz, but still fine with -20db after about 150ms. 200-300ms range? typical room and not so good). But we are a bit off topic, sorry about that :-)Not sure what you mean by time domain behavior. Of course we are assuming that you've taken care of delay and phase relationships so you have a smooth response.
Achieving a smooth frequency response is the result of managing delays and equalization and is talked about all the time with regard to subwoofers.By time domain behavoir I simply mean all the bass from the very low to the very high hitting your chest at about the same time, so that you physically can feel the kick
This is bass decay. Step one is delays and equalization to smooth the response which greatly enhances bass decay. What's left below 100 Hz (from the room, etc) probably can't be changed by absorption, but from 100 Hz and up can to various degrees of success.as opposed to just massive bass rumbling around in your room for too long, and starting at different times. And then there is the decay. The bass has to stop quickly too, to make this experience complete and that depends on the room properties (dimensions and absorbtion).
I think you're mixing things up here. You're right that if people don't properly integrate their subs they're not going to get the best experience - but room correction is part of that, not separate from it.I think too many people are crancking up their subs instead of getting them to kick at the right time and phase with their mains. Sooo much can be achieved there, with simple means. And then some room correction afterwards...
Yeah I think we mostly agree, except I don't think I am mixing things up too much. The main point I tried to make is that there is a difference between the frequency domain correction most people are concerned about, and the resulting measurements they look at, and the more complex picture, meaning also considering how the sound pressure increases and decreases at differenent frequencies as a function of time in a typical room. Both can to a certain extent be corrected with DSP, but typically the frequency domain more so than the time domain unless you allow for long filters and thus large latencies. Time domain correction depends on the SW capabilities and the acceptable max latency for a given situation. I think currently only Audiolense, Accurate and possibly Trinnov corrects the time domain with proper user adjustments, please suggest others if I missed anyAchieving a smooth frequency response is the result of managing delays and equalization and is talked about all the time with regard to subwoofers.
But they are interrelated. Adjusting delays affects the frequency response.Yeah I think we mostly agree, except I don't think I am mixing things up too much. The main point I tried to make is that there is a difference between the frequency domain correction most people are concerned about, and the resulting measurements they look at, and the more complex picture, meaning also considering how the sound pressure increases and decreases at differenent frequencies as a function of time in a typical room. Both can to a certain extent be corrected with DSP, but typically the frequency domain more so than the time domain unless you allow for long filters and thus large latencies. Time domain correction depends on the SW capabilities and the acceptable max latency for a given situation. I think currently only Audiolense, Accurate and possibly Trinnov corrects the time domain with proper user adjustments, please suggest others if I missed any![]()
With my new 20" ASC Isothermal tubetraps I achieved significant improvements down to about 40Hz or so in terms of decay times. And exceptional results around 80Hz where it really matters. Not so with my earlier "bass traps" from GIK etc:-)This is bass decay. Step one is delays and equalization to smooth the response which greatly enhances bass decay. What's left below 100 Hz (from the room, etc) probably can't be changed by absorption, but from 100 Hz and up can to various degrees of success.
