- Apr 3, 2017
- 8,393
Updates from the test versions have been included in the V5.20 beta 60 release.
Thanks. I will ask D&D then.There shouldn't be, REW is a signed and notarized application so should be enabled automatically for access. If you have turned on "Stealth mode" in the Advanced Settings that might have an effect, otherwise make sure the 8c firmware is up to date and if it already is may be best to check with D&D.
REW keeps some log files in ~/Library/Logs/REW, if you attach the rew_output.txt file from that folder there should be some diagnostic info that might help work out what is happening.
Difficult to draw any conclusions, unfortunately. It looks like REW often doesn't get a response when it looks for the speakers, and even on the occasions when it has had a response a subsequent attempt to connect to them times out. Probably best following up with D&D and letting them have a copy of the rew_output.txt file.
The original error is no route to host when trying to send a packet to find the 8c's, that might be due to a firewall being active preventing REW accessing the network interface.
