Matthew J Poes
- Oct 18, 2017
- 1,904
That's good news! Otherwise it meant I wasn't understanding
So, towards the 35Hz peak and long decay time: any of the above models strikes you as clearly better?
Regarding the other peak, around 55-65Hz:
- 2nd length mode is at 70Hz
- 2nd width mode (panel door to window) is at 68Hz
- if we assume the panel door does very little, the extension of the room is the same width, so 68Hz would be f3 from brick to glass width.
- SBIR: I'm looking at the subwoofers given their xo at 80Hz. Both subwoofers cones are 68cm from the front wall so not aligning well with this peak as far as I can see. But their cones are 12" and centers are 23cm from the floor, so could be 5/4 of the wavelengths within 60 to 70Hz.
Seems 3 factors are piling up here: 1) f1 length axis, 2) f1 width axis, 3) 5/4 WL from SWs center to floor. Addressing this looks like my next target![]()
The modes at those higher bass frequencies will be far more audible than the 35hz peak.
As for how to address the axial mode, the problem is that its so powerful (as this mode always is). A couple of corner bass traps or limp mass bass traps does very little. What I've found is that EQ is actually the easiest solution. That is my main recommendation. When that is not possible, then my next suggestion is to treat 100% of the front and rear wall with bass traps taht are heavily biased toward the frequencies below 80hz. One option is to use Helmholtz, panel, or membrane traps in the corners and covering the entire rear wall. Tuning to 35hz is tricky.
Take a look at this commercial offering:
http://www.gikacoustics.com/product/gik-acoustics-scopus-tuned-bass-trap-t40/
it's 4 square feet and 10" deep. Anything you build will likely end up with a finished depth very similar to this, to drop it further to 35hz, it would likely be even deeper. My own experience with these products is that trying to address this problem is not solved by 1 or 2 of these products. 4-8 square feet won't cover it. It ends up needing to be something like 20-30 square feet of coverage, basically most of the wall. I would be prepared to give up 10-12" of room depth and 16-20 square feet of wall space to make this work.
